5 grand idle ??
Old 09-20-2004, 11:29 PM
Liquid Teal's Avatar
5 grand idle ??
new plugs,wires,opti...cap,etc.
idles cold or hot at about 5000....whats up w/ that ? any known cures ?
thanks
~Dave
Liquid Teal is offline
Old 09-20-2004, 11:31 PM
RedThunder1994's Avatar
Re: 5 grand idle ??
i think your engines wanting you to go to the track :-D
RedThunder1994 is offline
Old 09-20-2004, 11:32 PM
Tair's Avatar
Re: 5 grand idle ??
dude...5000?!?!....is your foot on the gas?
Tair is offline
Old 09-20-2004, 11:37 PM
Re: 5 grand idle ??
would almost have to be lol man r u sure u arnt tryin to neutral drop or flashin stall or somethin crazy because damn thats quite high, i hope u arnt drivin it like that
Old 09-20-2004, 11:41 PM
Re: 5 grand idle ??
LMAO.....
correction--->>>>> how about 500
Old 09-20-2004, 11:42 PM
Re: 5 grand idle ??
whast wrong with 500, yea its a little low, but hell better than 5000
Old 09-20-2004, 11:45 PM
Re: 5 grand idle ??
my friend actually had a problem with his car runnign at a low rpm also and also with dieing while driving sometimes, his was fuel pump, very easy to change out IF u do the hole in back thing, its actrually very easy to do it that way, saves LOTS of time and cuss words, i recommend u get a fuel pressure tester from advanced auto or auto zone and test the psi, and when u turn the car off it should hold the psi at that level when car is on or no more than 10 below it, thats my guess
Old 09-20-2004, 11:48 PM
tfs95z28's Avatar
Re: 5 grand idle ??
too funny, yeah if it was idleing at 5000, id say the motor would probably be shot in a matter of hours. 500 aint that bad, 700 is the norm.
tfs95z28 is offline
Old 09-21-2004, 08:36 AM
Re: 5 grand idle ??
Stock programming for an A4, fully warmed up, is 550rpm in gear and 650rpm in neutral. There is a cold idle table:
A4:
COOLANT TEMP - IN GEAR - IN NEUTRAL
-40 ------- 800 ---- 1200
-19 ------- 800 ---- 1200
+3 -------- 800 ---- 1200
24 -------- 800 ---- 1000
46 -------- 800 ---- 950
68 -------- 800 ---- 900
89 -------- 800 ---- 900
111 ------- 800 ---- 900
132 ------- 750 ---- 850
154 ------- 650 ---- 750
176 ------- 550 ---- 650
>176 ----- 550 ---- 650
If the idle doesn't match properly, it may be a problem with the IAC valve, or plugged passages for the idle air flow. Check the IAC valve "counts" with a scanner, and see how it reponds.
Injuneer is offline
Old 09-21-2004, 08:38 AM
tfs95z28's Avatar
Re: 5 grand idle ??
that is very thorough I must say. Nice to see the real raw numbers.
tfs95z28 is offline
Old 09-21-2004, 10:51 PM
Re: 5 grand idle ??
Thanks guys.....I appreciate the input. Guess mine is about normel then...er umm , was..... posting a new topic w/ new problem.
Nayr
03-03-2023 08:34 PM
ducttape1975
Classic Engine Tech
03-26-2016 04:17 PM
tdigger9899
09-07-2015 10:56 AM
FredM
08-14-2015 01:49 PM
ducttape1975
07-10-2015 06:29 PM
Quick Reply: 5 grand idle ??
