383 build. What oil pump and Windage tray on stock pan?
I think I made a few mistakes along the way.. I already went ahead a purchased the Melling HV pump and drive shaft.. I should have went with the stock pump from what I have been reading.. I completely forgot about the windage tray.. I have no clue what to use.. Can someone help me out???
Re: 383 build. What oil pump and Windage tray on stock pan?
I'm using the mellings stock replacement with the supplied hp spring.The windage tray I'm using is the Milodon Diamond stripper, using their stud kit.
The acual only clearancing I had to to was so the pan could clear the long windage tray studs, The tray is adjustable with nits so you can raise or lower it to miss the crank and rods.
I was just about to email you. lol.. I found a post you replied to awhile back about the summit pkg.. they still have that? How much is the windage tray? Will all this work with the stock oil pan? Is this all I need to put the bottom end together?? (rotating assembly is already in).. whats your instant message name?
I don't have any IM capability (at work and lo tek at home...lol).
Anyway , yeah they still have that Oil pump package with the shaft (pinned), welded on pick-up and moujnting stud for the pump, if I remember right its about 60 with their pseudo shipping charge. The tray is another 75 $ and the stud kit is 45 $ if I remember right.
Yeah minor clearancing will fit over the crank and into the pan.
I checked the part number for the pump kit.. Its says Chevrolet: 1965-92 262-400 passenger car and 1/2 ton pickup, 1976-79 Corvette, standard volume, oil pump combo.. you sure thats the right one?? SES-3-60-08-005
Yep, Thats it. I used the high pressure spring they send with it and my oil pressure is at least 40 all the time and goes up close to 70 under throttle
WOW.. just found out that combination sent me the melling stock replacement one.. PT number 10552.. owell.. But yea im sending that back and im getting that summit one.. Thats with the pump and everything i need right??
I believe the stock replacement with the high pressure spring it the melling M55A, also known as the Z28 pump. If running a stock size pan, this is the one you want. Let me know if im wrong.
Brandon
Brandon
Originally Posted by RobbyRob
Remember to set the clearence for the oil pick up from the pan....
Yep allways do that, the best way I have found to do it is place a peice of clay on the bottom edge of the pick-up and install the pan with gasket, then remove and measure, I like 3/8s of an inch between the bootm of the pick-up and the pan, the pickup can be easily bent into proper place.
The Summit Kit comes with the mellings stock replacement pump (M55) and an extra spring for higher pressure,a steel pinned sleeved drive shaft, mounting stud, nut and washer.
10-31-2016 11:09 AM
