355 rebuild
355 rebuild
What pieces would you guys recommend with this? I want to put a GM 847 cam with ported stock castings on it. Who sells this rebuild kit and what not. I want to do a 355, not sure if I want to go the route of a 383, not looking to make a big monster out of it, and a 355 sure seems like a good street/strip set-up. Maybe even a custom cam, but it will still be similar to the 847.
-Eric
-Eric
Re: 355 rebuild
I just got my engine completely broken down just about 5 minutes ago. I would recommend the summit forged rebuild kit. It comes with forges pistons, rods, freeze plugs, main and rod caps and bearings and a high volume oil pump. Basically everything you need. Then purchase a scat 9000 crank.
But then you could call me biased because thats the setup I am going with.
