355 build up ; Engine wizzards, please look
I just wanna make sure i got the right stuff and it all works. hate to put it together to find a pistons comes out the top of the block or the crank wont fit lol
Budjet 355
Crank
Legend Nodular iron (same as scat 9000 apparantly)
Specs
Balanced internally
stroke is 3.48
Taget bob weight is 1870 +- 2%
Rods journals/ bearings 2.100 ''
Main journals/ bearinds 2.449 ''
Rods 5.700 '' or 6.000 ''
600hp and 7250 RPM
1 peice rear main
".092 ROD RADIUS FOR SUPERIOR STRENGTH WHILE MAINTAINING THE USE OF STOCK BEARINGS!! MAGNAFLUXED AND INSPECTED, INDEXED FOR STROKE, AND BEARING SURFACE DIMENSIONS!! FULL COUNTER WEIGHTS, BALANCED TO OE SPECS. STRAIGHT SHOT OILING. LIGHTENED ROD THROWS. READY TO INSTALL"
Brand new $125
RODS
Eagle SIR6000BBLW forged 5140 lightwieght I-beam rods
6.000''
2.100 rod journals
rated to 600hp
ARP wavelock 3/8 bolts
$179 new
PISTONS
WISECO pro tru forged PT008H3
bore size: 4.030
stroke: 3.48
rod length: 6.000''
Comp height 1.260
dome volume -5.4
comp with 67cc head 10.0:1
Comp with my 52cc heads
Rings: Hastings Hi-Tensile Plasma Moly
chomemoly pin
$389 new
TOTAL $693
of course, plus bearings
WILL IT ALL WORK TOGETHER?
ANY BAD EXPERIENCE WITH THESE PARTS?
WHAT WILL NEED TO BE DONE TO THE BLOCK?
Obviously boring out the cylinders to 0.030'' but what else?
ALine hone?
How much would you thing a good price would be for a builder to do, and assemble to a shortblock?
THANKS, really really appreciate the help. i dont know jack lol
Budjet 355
Crank
Specs
Balanced internally
stroke is 3.48
600hp and 7250 RPM
1 peice rear main
Brand new $125
RODS
6.000''
2.100 rod journals
rated to 600hp
$179 new
PISTONS
bore size: 4.030
stroke: 3.48
rod length: 6.000''
Comp height 1.260
dome volume -5.4
chomemoly pin
$389 new
TOTAL $693
ALine hone?
Dude thats some serious crap. Take it to the machine shop. No one here will dare answer that and I wouldn't believe um if they did. What I did...if fact I get my motor back tomorrow, is let the machinist to the block work...(clearance..balance...deck..align hone.) When they balance it and clearance the block they will spec all that. Get it back from them and assemble it yourself.
I can tell you that the piston wont stick out with that combo:
strock = 3.48/2 = 1.74
Rod = 6
compression hight = 1.26
1.74 + 6 + 1.26 = 9
Theoretical deck hight is 9.025".
You can mill the block top to get a quench hight of 0.045".
Rod = 6
1.74 + 6 + 1.26 = 9
I was pretty sure all the measurements worked out. I was more of looking for coments of the parts being used. Like "thats not gunna be as strong as blah blah" or "legend cranks suck" or those rings suck" or Hopefully, "sounds like an awsome set up man!"
I am in need of a rebuild and im having to take out a loan to do this. I have been going back and forth betweet all forged and 383s etc... My two housemates have 396ci solid rollers and are trying to get me to do at least a 383. But considering i dont really have the $$ to do this, i better keep it under control and to a small amount. But not so small that its pointless ya know?
And I have an engine builder that great, 30 years of experience and he know his stuff. only think is what come with 30 years of experience he is very very old school. I went out the yesturday and he was going of on one of his tangets about i would have to putt a chevy 400 crank and bore out all the mains, do this and that. Not much 2 gen and 3rd gen sbc experience and also he does know about all this new stuff that they make to ease the modifing our 327 blocks
But as long as this set up seems ok, i will take it out to him and let him take a look.
lt1 block, main journals are 2.5(2.499) right
Althought i thought this wasn't that advanced, should i posted it there anyway?
You got that part right. Mine turned into a snowball. I blew my motor and went with the 383 thinking it'll just be a little more. I was way wrong! WAY MORE. It's all the little things that kill ya. Bigger injectors...250, bigger tb 390, the extra machining, gotta beef up the tranny. Gotta do the heads to make the 383 flow and use the power (port and polished myself 49 hours). You'll be amazed about how they add up. If this motor (going in tomorrow) don't put out, I'm gonna wish I stayed with the 355.
Guess im gunna get this stuff ordered
10-31-2016 11:09 AM
Bearmans
12-03-2014 05:28 AM
guionM
10
09-08-2002 11:08 PM
