1995 Z28 overheating
Old 02-13-2013, 11:00 PM
  #16
98 3.8's Avatar
Re: 1995 Z28 overheating
my 98 Camaro has new water pump and thermostat and im not getting any heat in car runs at 230 at idle and tries to go to 260 driving lines hot as fire on driver side and warm on passenger side any ideas on how to fix
98 3.8 is offline
Old 02-14-2013, 08:26 PM
  #17
Just Build It's Avatar
You said that you burped the system and mentioned the radiator cap. You never mentioned the air bleeds. I know my 94 has two one on a heater hose on pass. Side and the other on the thermostat housing this one is not in plain sight. I have had similar problems with other GM vehicles caused by not properly bleeding the system.
Just Build It is offline
Old 05-29-2015, 01:04 PM
  #18
95z28 ariel's Avatar
Originally Posted by JackBlack95
Have you been driving my car? LOL I have the identical problem......
My car is doing the samething. It heats up then drops, heats up then drops. It was running perfectly fine until it started heating up yesterday. Tried bleeding the system, replaced the thermo and still doing the samething. 😒�
95z28 ariel is offline
Old 08-02-2015, 10:40 PM
  #19
jjbmxer's Avatar
Gotta use those bleed screws. both of them should have steady coolant flow no air. cars with air pockets will heat up
jjbmxer is offline
Garcia5
07-07-2022 06:51 PM
calaban
05-18-2020 06:43 PM
10-31-2016 11:09 AM
edxiel
01-24-2015 07:40 PM
01-05-2015 07:14 PM
Quick Reply: 1995 Z28 overheating
