1995 z28 cam and upgrades
Old 11-21-2016, 11:11 AM
Fernie_z28_6897's Avatar
Ok so I'm looking into camming my Camaro which cam do u guys recommend and what other modifications do u guys recommend doing
Fernie_z28_6897 is offline
Old 11-21-2016, 04:13 PM
Chimera96's Avatar
Re: 1995 z28 cam and upgrades
contact Lloyd Elliott and discuss your goals. If car needs to pass smog, using stock or ported heads, etc all are a factor.
Chimera96 is offline
Old 11-21-2016, 10:58 PM
Emissions obviously a major issue in CA.
http://elliottsportworks.com/
What mods does your Camaro have already?
Injuneer is offline
Old 11-22-2016, 10:58 PM
It really doesn't have alot of mods it has a k&n intake hooker header and stage 1 shift kit
Old 11-23-2016, 10:41 PM
Hey quick question that Elliot guy where is he's shop at
Old 11-23-2016, 11:00 PM
timnfxr's Avatar
Contact Info«
timnfxr is offline
Old 11-23-2016, 11:01 PM
But I'm in ca in Los Angeles
Old 11-23-2016, 11:22 PM
Fatdog2's Avatar
Hi,I'm over by Magic Mountain.Do you know what hookers you have.Shorty's,mid range or long tubes because the Ca.smog stations won't pass the lT's.or even the mids.I've been contemplating some pipes down the road someday.Many thanks.
Fatdog2 is offline
Old 11-23-2016, 11:28 PM
The headers are hooker shorties and I have a friend that pass my smog
Old 11-24-2016, 02:09 AM
KW Baraka's Avatar
And that's why UPS is a thriving business.
Find a competent shop in the LA area to do the install of your parts....and then....contact Lloyd and get a complete heads/cam setup from him along with recommendations on other necessary parts.
Otherwise.....you can try finding a shop in LA to port your heads and select a cam for you......but you will note that no one has recommended a LA shop for that; right?
Best of luck!!
KW
KW Baraka is offline
Old 11-24-2016, 03:19 AM
Tell me about it I work for ups right now is the busiest time of the year for us so I can order the parts from Elliot and have them ship to me
Old 11-24-2016, 07:06 AM
You send him your LT1 heads and intake. He reworks them and sends them back.
Injuneer is offline
