1994 z28 tune up lt1 ?? why Chevy why
Old 07-02-2015, 11:32 AM
colts0455's Avatar
my cars running rough looked at the drive side plugs & wires im pretty sure been longg time since they been done couldn't even see passenger side wires & plugs why in the world are they made like this ?? and any info on best way to change them best wires & best well at good price one shop told me 500 to do it another said 350 and best i got so far was 200 that sound crazy for a tune up to me
colts0455 is offline
Old 07-02-2015, 11:50 AM
Re: 1994 z28 tune up lt1 ?? why Chevy why
It can be a difficult job, especially on the passenger side. IMHO, best bet is a set of genuine ACDelco plug wires. Info on changing plug wires can be found with a search, but opinions vary on how to do it. It usually comes down to how a strategy works best for you. One strategy does not work for everyone.
shoebox is offline
Old 07-02-2015, 02:05 PM
Some of the plugs on the passenger side are reached from under the car. #2 at the front can be accessed best by removing the alternator.
Injuneer is offline
Old 07-02-2015, 04:26 PM
blac94Z's Avatar
do you still have all your smog equipment hooked up ? bc if not you can kill the all from the top
blac94Z is offline
Old 07-03-2015, 06:36 PM
colts0455's Avatar
update plugs was baddd and 2 out of the 8 wires was broke could see wires its been alone time since its last tune up she feels good now knock on wood but another ?? is my temp half way hot good ? i put new radiator in 180 thermo new anti freeze still seems to when i idle it goes up to half way to a lil just a lil over half ?? maybe i worrie to much
Old 07-03-2015, 07:19 PM
timnfxr's Avatar
The temp gauge half way up (is ~210F). The fans with a stock PCM tune are programmed to turn on the primary fan at 225F (driver side), and secondary fan at 235F (pass side), which the 3/4 mark on the gauge.
Sitting at idle for a period (especially on warm days), it's common for it to hit the half way mark. As long as the fans turn on, it should keep the temps in a safe range. You never want to let it exceed the 3/4 mark (~235F). When normal driving, it should stay cool enough that the fans shouldn't need to cycle.
timnfxr is offline
Old 07-03-2015, 08:07 PM
colts0455's Avatar
the temp gauge was half way and i jumped under it both fans was on it only got just a lil i mean justtt a lil above half way yea its all stock ive done nothing to it but what i listed tune up and new radiator
Old 07-03-2015, 09:05 PM
How the fans operate depends on when in the 1994 model year your car was built. "Early" in the year they used the strategy described above - first fan on at 226°F, second fan on at 235°F. "Late" models turn both fans on low speed at 226°F, both fans on high speed at 235°F. If you have the A/C on (or defrost) the first fan, or both fans on low will turn on no matter what the coolant temp.
Look at the fan relays in the under hood fuse box - 2 relays for the "early" system, 3 relays for the "late" system.
As noted above, the mid-point of the gauge is 210°F, and that is normal for hot weather idling.
Hopefully, you bought the correct LT1 type t'stat. You can't use a standard small block Chevy t'stat, and that's what many auto parts stores will sell you.
Injuneer is offline
Old 07-03-2015, 09:38 PM
colts0455's Avatar
ive got 3 coolant fan relays under the fuse box i put all new fuses in i do know that much
Old 07-03-2015, 09:40 PM
colts0455's Avatar
and i told parts store 94 lt1 thermo i needed
Old 07-03-2015, 09:59 PM
Which guarantees nothing , but if it looks like this, you are ok.
shoebox is offline
Old 07-04-2015, 09:24 AM
colts0455's Avatar
true and i know the one i pulled out looked like the lt1 the new one ehh was long day let me see if i can find the box
Old 07-04-2015, 09:49 AM
colts0455's Avatar
found the box i got it from advance auto parts paid 14 bucks heres the link Superstat Superstat™ Super Premium Thermostat, 180 Degrees Fahrenheit 45218: Advance Auto Parts
Old 07-04-2015, 01:04 PM
Looks like the right one. The $14 almost guarantees it by itself. The normal SBC thermostat is only a few bucks.
shoebox is offline
Old 07-04-2015, 02:32 PM
colts0455's Avatar
good i was sure just bought so much lil stuff here and there in past week next onto the ac and im hoping ill be done knock on wood
Noenav
03-01-2019 07:38 AM
NorthPoleDev
12-31-2014 03:20 PM
thenewkid
11-27-2014 09:41 AM
94z28jbw
09-08-2002 03:22 PM
Burn_Out
08-18-2002 08:49 AM
Quick Reply: 1994 z28 tune up lt1 ?? why Chevy why
