What does this plug in to?
Re: What does this plug in to?
No. The low coolant level sensor is only connected to the "low coolant" light on the dash (and to the BCM for a "latching" feature). If you unplug the harness connector, the dash light stays off. It is not connected to the PCM and will not result in an SES light.
There's a good chance the low coolant sensor is dirty or corroded, and is causing the "low coolant" light to stay on, so someone unplugged the sensor to turn the light off.
From Shoebox:
http://shbox.com/1/low_coolant.jpg
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
http://shbox.com/1/low_coolant2.jpg
From Shoebox:
Nah im pretty sure when i got a new water pump they never plugged this back in. I talked to the previous owner and he said he never unplugged it.
No light comes on with it in, either.
Yeah the light randomly came on after I drove it yesterday while it was plugged it. The coolant level is fine, so I'm guessing the sensor or wire is shot. The light stayed off all day today though....
It's most likely the sensor. Just drain the coolant below the sensor level and swap it out with a new one. Don't bother trying to clean it and all that nonsense. Been there, done that, didn't work. Best to get a new one.
14
08-11-2015 12:03 PM
zajones
07-30-2015 02:18 PM
