160 thermo stat ?s
Re: 160 thermo stat ?s
nope you don't need any programming. You might have to bleed the coolant system after your done. Other than that its just a simple thermostat install. I would probably put silicone around the housing though because if it leaks any its all gonna land on the opti.
Good ?
I guess it resets the PCM
I'm new at this NEW car stuff the last car I had was a 1968 Impala with a 327,,, before that it was a 1978 Z28 I had for 20 years.
Never owned a car newer than that!!!
They did not have this crap on um!
That still doesn't explain why you are pulling the pcm fuse. If you are pulling it for some reason related to the thermostat install. I'll just save you the time. You don't need to pull it.
I didn't even know there was an "overheating" light. I guess i've never had that problem. I do know there are 2 temperature sensors on the car maybe one is bad. That might be why your gauge reads fine 190 and the other one thinks the car is getting hot.
