12499224 LS6 Yellow Springs
Old 11-05-2006, 07:32 PM
Kwik89GTA's Avatar
Will the 12499224 GM LS6 "yellow" springs work on a LT1 in place of the 918 beehive springs? They are substantially cheaper. It looks like you could use them with the Comp Cams LT1 beehive retainer, but I can't be sure.
Anyone have these on a LT1?
Kwik89GTA is offline
Old 11-05-2006, 07:35 PM
jay_lt4's Avatar
should work fine,but they are only good too .550" lift
jay_lt4 is offline
Old 11-05-2006, 07:47 PM
Kwik89GTA's Avatar
Sounds good, I'm running the CC305 with the LT4 1.6 roller rockers. Should have lift right around .544. SDPC lists the yellow springs as good for .588 lift but GM parts Direct lists the maximum lift as .550. I still think that I should be safe either way......
Old 11-05-2006, 11:57 PM
SStrokerAce's Avatar
Yes and no, not as much pressure or lift potential as a 918. Belive me Lloyd and I have looked at using them for the LE1 package but that wasn't going to work.
Bret
SStrokerAce is offline
Old 11-06-2006, 05:31 AM
Kwik89GTA's Avatar
Do you think that these springs will be fine with the CC305 and 1.6RRs?
Old 11-06-2006, 12:56 PM
Depends on how many good ones you get in a batch..... With 1.5's and them installed tight enough yes. There is not enough seated pressure if you set them up too high.
Bret
LETZRIDE
Outside of United States
07-09-2015 07:17 AM
R@mpage
04-20-2015 10:02 AM
racecarz28
03-30-2015 09:55 PM
LT14LIFE
02-09-2015 09:35 PM
Quick Reply: 12499224 LS6 Yellow Springs
