1.6 Roller Rockers
Old 10-04-2004, 08:47 PM
CamaroGuy22's Avatar
1.6 Roller Rockers
I am thinking about purchasing 1.6 comp cams magnum self-aligning rollor tip rockers. I did a search but didn't find what I wanted. What kind of gains would i be likely to see with these with an otherwise stock motor.
Do i need to purchase anything else?
CamaroGuy22 is offline
Old 10-04-2004, 09:02 PM
Fuels94TA's Avatar
Re: 1.6 Roller Rockers
That's what i'm running and they are decent RR. (if you want to see what they look like just check the sign of the car) I've heard people say they kept the stock springs without have problem, but also with the extra lift from the RR the springs could bind up. I would go all out and change the spring as well. You can get a full set of LT4 spring under $50 from gmdirect.
Fuels94TA is offline
Old 10-04-2004, 09:07 PM
Z95m6's Avatar
Get promags. You will gain some power from the extra lift of the 1.6's but you would gain more power from the promags as they provide less friction.
Z95m6 is offline
Old 10-04-2004, 09:08 PM
94z28_LTI's Avatar
by gmdirect do you mean from a dealer or a seperate out fitter i.e. gm performance?
94z28_LTI is offline
Old 10-04-2004, 09:33 PM
Fuels94TA's Avatar
Originally Posted by 94z28_LTI
gm performance?
Thats the one
Old 10-05-2004, 12:10 PM
I heard that the LT4 springs were weak, is that true? What power gains should i be seeing from a rocker change.
Old 10-05-2004, 12:31 PM
dmoor88's Avatar
some have seen ~10 rwhp on an otherwise stock motor.
dmoor88 is offline
Old 10-05-2004, 02:30 PM
Z95m6's Avatar
LT4's are fine for a stock cam, and are ok for the hot cam. Although i've heard of valvefloat on the hotcam with the LT4's. Anything more than a hotcam you will need better springs. My buddy knew what cam he wanted when he installed his roller rockers so he installed the valve springs for that cam and ran it with RR's until he was ready to do the cam.
Z95m6 is offline
Old 10-05-2004, 05:49 PM
Fuels94TA's Avatar
ditto....on the springs
Old 10-05-2004, 06:15 PM
Z06Z28's Avatar
Is there any difference between the Crane Gold Rockers vs Comp Pro Mags? A lil difference in Price I know but what else... ?
Z06Z28 is offline
13qtr
10-28-2016 08:11 PM
football4life
10-04-2015 07:48 AM
9t4lt4z28
10-02-2015 10:28 AM
MDZ28
11
09-24-2015 09:15 AM
Z Power
09-19-2015 11:19 PM
Quick Reply: 1.6 Roller Rockers
