what is the percentage difference between rear wheel hp and flywheel hp?
Old 10-03-2002, 01:29 PM
02MidnightblueZ28's Avatar
Question what is the percentage difference between rear wheel hp and flywheel hp?
What is the percentage difference between rear wheel hp and flywheel hp?
02MidnightblueZ28 is offline
Old 10-03-2002, 01:43 PM
Silver NJ_Z28's Avatar
Flywheel horsepower is the measurment used by car companies. They just strap a dyno to the engines flywheel, which the the first thing the crankshaft touches.
Most people dyno their horsepower at the wheels. There is always some parasitic loss through the drivetrain to the wheels so there is less horsepower read at the wheels.
Flywheel = at the engine, more hp
Wheel = at the wheels, less hp
So an average loss is about 15% in a manual. Which means that a Camaro with 320 hp at the flywheel will have 272 at the wheels.
Silver NJ_Z28 is offline
Old 10-03-2002, 03:11 PM
BlackHawk T/A's Avatar
There isn't one.
Why? Because it is exponential. The more power you have the more will be lost to the wheels - and it will not stay a fixed percentage either.
15% and 20% are generally true on a stock LS1 F-Body, but once you start upping the ante those numbers will change.
We debated this forever on LS1.com and have pages of information. I will post a link to the thread as soon as the site is back up.
Edit : http://www.ls1.com/forums/showthread...hreadid=151557
BlackHawk T/A is offline
Old 10-03-2002, 04:02 PM
ratio411's Avatar
Whenever the subject has come up on LS1.com over the last few years, the general consensus ends up being about 12% for M6 and 18% for A4. The percentages are lower now than when I went to school, back in the day they were 15% and 20%, but the fact is that drivetrains are alot more effiecient today than they were 20-30 years ago when those higher numbers were considered the norm.
As long as drivetrain rotational mass doesn't change, the power loss should remain a constant percentage no matter what kind of power you have.
Dave
ratio411 is offline
Old 10-04-2002, 03:38 AM
10-31-2016 11:09 AM
dpw21562
01-23-2015 04:58 PM
Moshbmx1
01-20-2015 03:27 PM
blac94Z
11-24-2014 07:12 PM
squarehead
11-21-2014 08:02 PM
Quick Reply: what is the percentage difference between rear wheel hp and flywheel hp?
