What does LS-1 stand for?
Old 11-24-2002, 05:32 PM
Tripp's Avatar
Question What does LS-1 stand for?
does LS-1 stand for anything?
Tripp is offline
Old 11-24-2002, 06:35 PM
SpecForceZ28's Avatar
It stands for your engine code, in fact, all the options your car came with would be posted as a code, on a sticker on your driver side door. LS1 means you have the 5.7L V8, same engine in the C5 corvettes.
SpecForceZ28 is offline
Old 11-24-2002, 06:39 PM
SteveC's Avatar
Smile
"LS1", is a GM factory code for the type of engine you have. Some other engine codes are: LT1-346ci cast iron block, aluminum heads, LT4-454ci, 425HP (I think). More codes of engines, even though I do not know the specs are, ZR1,L89,LS4- 396cu, 375HP.
Hope this helps you out in some way.
SteveC
SteveC is offline
Old 11-24-2002, 07:13 PM
Moderator
PhantomTA's Avatar
Your way off on what Code is what engine..
I MEAN WAY OFF!!!
anyways..
it just an engine code.. nothing else
PhantomTA is offline
Old 11-24-2002, 09:44 PM
SS_Thunder's Avatar
LT4, 454 CI????
SS_Thunder is offline
Old 11-24-2002, 11:12 PM
LS4? I think its LS6, and LT4?
Old 11-24-2002, 11:28 PM
Tripp's Avatar
ls-1
ls-1
i know i have the same engine as a c5 and what not. what i ment to say what does the "L" and the "S" stand for?
well obviously it dosent mean Lingenfelter. are they initials for anything?
Tripp is offline
Old 11-24-2002, 11:35 PM
2002Z28SSConv's Avatar
doubtful
2002Z28SSConv is offline
Old 11-24-2002, 11:58 PM
nope, none of the codes on the camaro's can be put that way, at least I don't think
Old 11-25-2002, 07:19 AM
Moderator
PhantomTA's Avatar
Re: ls-1
Originally posted by Tripp
ls-1
it means nothing.. its a code...
Victor Lamb
08-26-2017 02:52 PM
football4life
10-04-2015 07:48 AM
4586
09-27-2015 01:55 PM
Boss002
07-09-2015 03:33 PM
fastenuff
09-06-2002 10:57 PM
Quick Reply: What does LS-1 stand for?
