What do I need for ls6 upgrades from ls1. - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 10-31-2013, 02:44 PM   #1
I have a 99 z28 I have a loose lifter and am planning on swapping to ported LS6 heads and intake, also going to put a mild cam in. I want it to run nice and smooth and was wondering since I have to replace a lifter if LS6 lifters would be ok to put in since I'm doing the LS6 swap and if there is anything else I will need to change. Also what would be a good mild cam? Any suggestions would be helpful. I'm also putting a transgo HD2 shift kit for it to run smooth and proper I thought about a 2800-3000 stall converter, I'm sure there is more ill need if anyone has some info on that I would be great full for the knowledge.
Stonerz28 is offline   Reply With Quote
Old 10-31-2013, 11:04 PM   #2
Super Moderator
JakeRobb's Avatar
Re: What do I need for ls6 upgrades from ls1.
I'm pretty sure LS1 and LS6 lifters are the same. While you have it opened up, put in a set of chrome-moly pushrods and upgrade to a better valve spring.
JakeRobb is offline   Reply With Quote
Old 11-01-2013, 04:54 PM   #3
WhiteHawk's Avatar
I used to run a Lingenfelter GT2-3. It was 207/220 .571/.578 118.5 LSA. I ran it with some cheap ported heads and my 02 Firehawk made 390 to the wheels on the stock tune. You need some good valvesprings for that lift, but it was a nice setup that drove like stock. If you don't mind getting a tune, I would go for a 224/224 .581/.581 114+4. You can similar cams from a bunch of different vendors. I would get a tune for running that cam, mostly just to fix the idle and driving characteristics.
Also, you will be kicking yourself if you don't go at least 3600 on a stall.
-Geoff
WhiteHawk is offline   Reply With Quote
Old 11-11-2013, 10:52 PM   #4
Mr99SS's Avatar
Quote:
they aren't ... ls1 ls2 lifters had a default so u can only buy ls6 or newer now
Mr99SS is offline   Reply With Quote
Old 12-28-2013, 03:02 PM   #5
I did a head/cam swap last summer and used Ls7 lifters for 598/598 lift cam.
birdblack is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Lt1 parts..cam/rockers..etc 13qtr Parts For Sale 24 10-28-2016 09:11 PM
Wtb ls6 intake JJOHNROE Parts Wanted 1 10-23-2015 03:03 PM
What to upgrade on my 4L60E? Mikes 1994 z28 Drivetrain 1 10-10-2015 08:55 AM
tuning software for 95 camaro? MDZ28 Computer Diagnostics and Tuning 11 09-24-2015 10:15 AM
timing tune Tarizza 3rd Gen / L98 Engine Tech 2 09-20-2015 04:26 PM
Tags
ls1 build, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
