Water pump help on a 02 Camaro ss 35th anniversary
Old 03-23-2013, 11:07 AM
SILVERADOSS's Avatar
Question Water pump help on a 02 Camaro ss 35th anniversary
Hi, I just removed the water pump on my 02 LS2 . I have new aluminum gaskets that came with the new pump.They have the o rings installed on them.My block has o rings on them that fit into milled grooves.Looks like if I remove the factory ones & install the new gaskets, it doesn't completely seal where the grooves are milled. Should I install the new ones with the factory ones on.the block? Or is there another way of doing this correctly.I appreciate any help.Thanks, Dan
SILVERADOSS is offline
rockync7
01-01-2015 05:10 AM
Jazsun
12-29-2014 12:14 PM
Queens94z28
12-20-2014 09:11 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: Water pump help on a 02 Camaro ss 35th anniversary
