temporary malfunction question
Old 03-03-2017, 07:55 PM
Z4Ccoupe's Avatar
On a relatively new to me 99 Trans Am. Started the car a couple of mornings ago and it would not idle. It kept trying to die and would drop below 300 rpm. I drove it about 20 miles. It ran poorly the whole trip. But it would maintain an idle without help after it got hot. When I would let off the throttle, it would drop to 500 rpm and then slowly climb to 750-800 rpm. On the drive home later in the day it started normally and drove normally. While it was acting up, it showed no codes. What gives with this? Thanks.
Z4Ccoupe is offline
Old 03-05-2017, 09:36 AM
Super Moderator
JakeRobb's Avatar
Re: temporary malfunction question
"It showed no codes" -- did you hook up a scanner, or are you basing this on no SES light?
If the latter, scan it and check for pending codes
Best guess:a vacuum leak, or a bad sensor somewhede. Keep driving it; it'll set a code soon enough and send you down the right path.
JakeRobb is offline
Old 03-05-2017, 02:36 PM
Z4Ccoupe's Avatar
No codes was based on the lack of SES light. I have had a somewhat persistant knock sensor code, however.
Z4Ccoupe is offline
