t-56 problems help
Old 03-23-2003, 07:50 PM
Firebird9463's Avatar
t-56 problems help
hey, i have a 99 TA WS6 M6. I got her out today and my dad was driving and missed the 3-4 shift and put her in 2nd. Then later tonight i was driving i've had this problem before rarely in 3rd, but it grinds when i try to put it into gear sometimes. It goes into gear fine, but once i start to left the clutch out it grinds and kicks it out. When i help it really tight i can sometimes get it to stay in 2nd, but once i go to shift to 3rd its hard to puch it out of 2nd.
Anyone have this before or know whats wrong??? Need help ASAP thanks
Firebird9463 is offline
Old 03-23-2003, 09:41 PM
2002Z28SSConv's Avatar
Stock shifter?
2002Z28SSConv is offline
Old 03-23-2003, 09:46 PM
yep, stock hurst. Going to order the 5.0 or ripper sometime next month.
I've done searches from here to ls1tech, and i would ls1.com if it was up. Havent found much. Pretty much anything from the clutch to synchros to the gears.
I know there some tranny experts around here somewhere come share the wealth
Old 03-23-2003, 10:48 PM
00LukeyWS6's Avatar
I have bad news for you.
I had the same thing happening. When I put into third at low rpms with normal driving from time to time it would grind and kick out. It only happened once in a while for like a year. Then one day coming home from a nice trip I nailed it. First, then into second. 2 seconds after sticking it into 2nd gear all hell broke loose. The tranny just grinded like hell. The car wouldn't move without grinding. After giving my car to the dealer for warranty work they told me that third gear fell out taking with it 4th, 5th and 6th gear syncros. Practically they had to rebuild my whole tranny. You might have something else but that's what happend to me.
00LukeyWS6 is offline
Old 03-23-2003, 11:00 PM
sounds exactly the same for the whole 3rd gear deal. Might be something similar, but 1st, 4th, 5th, and 6th are still solid and 3rd still can be driven on fairly well. Its just 2nd that is pretty much useless right now.
Old 03-23-2003, 11:52 PM
00LukeyWS6's Avatar
All of my gears felt solid too untill my third gear decided to go on strike.
Old 03-24-2003, 09:56 AM
haha thanks you remember how much it costs or have any idea what it would be? It its up there in price i might just get up getting all the viper parts put in and steel shift forks and stuff. thanks
Old 03-24-2003, 12:08 PM
6spdpewterZ's Avatar
I just ordered my synchros today because, yes Third, decided to give out as well. After a while 4rth started and then my 2nd and so on... Look at www.ddperformance.com, the T56 synchro kit is $229 and came out to $240 w/ taxes. But now i have another problem, at a low rpm something seems to slip, my RPM's will go up then down. I just replaced my clutch and i am hoping that when I fix synchro's will fix the problem.
6spdpewterZ is offline
Old 03-24-2003, 05:37 PM
2K2SOMSS's Avatar
Here's the T-56 service manual if you want to tackle the job yourself.
http://www.ttcautomotive.com/English...-0610-0199.pdf
Direct from Transmission Technologies Corp. (the people who bought out Tremec).
2K2SOMSS is offline
Old 03-24-2003, 06:53 PM
sweet thanks i'm going to order parts from d&d for sure, the synchro kit and steel 3-4 shift fork. is there anything else i should grab while shes opened up?
Old 03-24-2003, 10:22 PM
00LukeyWS6's Avatar
Fix it before same thing happens to you that happened to me. The dealer cost was $2500 to totally rebuild the tranny, thank god for warranty.
Old 03-24-2003, 10:32 PM
talked to the tranny guy today, my friends dad is the owner of the shop. Their busy as heck right now but he said he'll get it in Monday next week. So looks like tomorrow i'm ordering some parts and shes gonna sit in the garage until Monday.
Old 03-25-2003, 12:05 PM
I'm going to order the synchro kit and steel 3-4 shift for from D&D.
Do i need a bearing kit also, or should i replace it (71k on car)?? If i dont really need it i'm just going to leave it out to save some money.
10-31-2016 11:09 AM
james007moore
01-01-2016 01:14 PM
blownxtreme
08-26-2002 03:28 PM
americanbadazz
08-05-2002 11:10 PM
Duke
07-31-2002 05:13 PM
Quick Reply: t-56 problems help
