Strange vibration humming help !!! - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 03-09-2014, 11:40 AM   #1
blackmamba-z's Avatar
Hey everybody , was on the road this past weekend , coming from York pa to New York City on my way back I was cruising at about 75-80mph there was a point in time where traffic speed up so I did the same , a few miles later. I notice my exhaust sounded different , and I had a drone type sound and vibration coming from the front of the car , car still accelerates but up around 70 mph it would make that drone vibration , still cannot figure what's causing this sound I pull over rev the car freely and nothing , regular driving nothing only does it when I'm up around the 60+ mark anybody has a clue what's going on here
blackmamba-z is offline   Reply With Quote
Old 03-09-2014, 12:03 PM   #2
Super Moderator
Re: Strange vibration humming help !!!
Info required - year of vehicle, trans type, any major mods to engine or drivetrain?
Injuneer is offline   Reply With Quote
Old 03-09-2014, 12:20 PM   #3
99 z ls6 engine swap , long tubes headers ,borla cat back , rebuilt transmission , Koni shocks, bmr springs ,adj pan hard bar ,bmr stb,lower control arms , just installed brand new rack n pinion in sept , the vibration start happening with a change in exhaust tone suddenly on the interstate , so I turned down my music n that's wat confirmed these symptoms
Old 03-21-2014, 02:41 PM   #4
akwa's Avatar
I would say to climb under the car and start pulling on stuff. See if an exhaust bracket might of came loose. Check that pesky air dam under the front bumper. Those love to come loose or tear and would make a humming noise but I'm not sure how it would play into the exhaust note unless you are hearing it wrong. Another idea that I have done in less populated areas is take a buddy with you and have him open the passenger door and hang out listening for the noise to help pin point it. I did that when my rear axel was making noise but from inside the car it just echoed.
akwa is offline   Reply With Quote
Old 03-24-2014, 11:29 AM   #5
I think i have a real bad exhaust leak, cause my gas milage is down as well and throttle response is slightly decreased
Old 03-24-2014, 03:45 PM   #6
Super Moderator
Do you still have cats? Possible one is starting to plug up????
Old 04-06-2014, 09:00 PM   #7
No cats off road y , cause has different exhuast note now
Old 04-08-2014, 10:17 AM   #8
Ok took my car to shop yesterday, n me n my mechanic was completely stumped , we check for exhaust leaks none, the car exhaust n everything sound fine from the outside but when in the cabin there is a slight grinding sound, and the exhaust sound completely different ,inside it went from the startard growl of longtubes and borla exhaust to a almost low flooded drone sound , acceleration still good no smoke no nothin im completely stumped atm
Reply
Thread Thread Starter Forum Replies Last Post
1994 Camaro Z-28, 850hp, Supercharged 396 w/NOS, 9.5@143 RUENUF Cars For Sale 6 03-13-2016 04:37 PM
4th Gen wiper motor rattles- vibration autoxr166 General 1967-2002 F-Body Tech 0 09-25-2015 05:21 PM
2002 vibrating driveshaft ryanhilsgen Drivetrain 9 09-21-2015 08:34 PM
94 Z28 Automatic transmission - engine stall - No codes present Nayr LT1 Based Engine Tech 3 09-05-2015 07:12 PM
Vibration @ ~2500-3k rpms RallyRed701/2 LT1 Based Engine Tech 3 07-20-2015 12:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
