Stock Z28/SS numbers
on a Z28 it should be about 13.2-13.5 in the 1/4 mile depending how u drive and i believe 5.1 seconds 0-60. on the ss will be a little bit faster but not much at all. im not sure about the exact numbers though for the ss
Almost every option that was available on the SS was available on the Z28 besides the "SS" package.
Traction control was an option available on all the cars. It's just a simple button/switch thingy.
Like Tom said, in theory, a Z28 with no options would be the faster of the cars because of less weight. But in reality, every engine/car will dyno slightly different numbers, that is just the way it is.
Originally posted by stik6shift98
if u think getting an ss will make u go faster your wrong...all an ss is is apperance and more cash
And yes none of this makes it faster.
But let's not be misleading.
Originally posted by psychocabbage
yeah mine is silly light! 4490 with 3/4 tank of gas and everything inside (spare and whatnot)...
Hardtops will be the faster ones, regardless if it is a Z28 or SS. The stripper Z28 were among the lightest, but you could have ordered a stripper SS (some years) as well, which rivaled the performance of the (light) Z28s.
Originally posted by MRZ28HO
I hope you meant to type 3490 and not 4490. Otherwise, that is a porker. My A4 SS (with a 1/4) weighed in at 3460, fully optioned (T-Tops and all).
I mean 3490... I figured it to have about 12.5 gallons of gas in the tank.. spare and whatnot still in car.. everything I would normally have.. (i still havent even seen my spare).. T-tops are on my car as well.. so I would assume that with only 3 gallons of gas at 8lbs a gallon.. should bring my car to 3420ish range.. so 3300's are possible if I were to strip it down some...
with me in the car add 200lbs.. If ever there was a reason to lose weight.. hehe
