Traded the bass boat for 98 Z Drag car
Old 09-04-2014, 11:22 PM
Suprabuilder's Avatar
Wasnt using the bass boat much and my current mkiv supra build is taking to much time and money to see the track anytime soon. So this drag car i was traded for is a 98 Z black on black ls1 car with a 6 speed originally. It is now setup for drag with a Th400. Well built ls1. Real nice billet specialty wheels with new m thompsons. 4 point bar with 5 point harness. Looks good. Sounds good. Rides smooth. Wondering what a car like this runs in the quarter and if its worth it to get it up to par and take it for a few passes.
Suprabuilder is offline
Old 09-06-2014, 10:30 PM
Super Moderator
JakeRobb's Avatar
Re: Traded the bass boat for 98 Z Drag car
Bone stock, an LS1 Camaro ran low 13s at 105-108mph.
Modded, I have seen them run over 200mph with low-six-second ETs.
You'll have to get some info about what's been done to the engine before we know where you'll fall in that range.
JakeRobb is online now
Old 09-07-2014, 04:58 PM
Wow low 13s stock?? That's not bad. Well this car is far from stock. Here are some of the mods.
Big lift lunati cam.
Billet mains.
Upgraded valve train- springs, rockers, p rods, keepers.
No p/s or a/c
Very nice lookin LT headers with BBk y pipe into single bullet muffler dumped before axle
Vertical 3 row alum radiator
No t stat
Hvac system completely
removed and plated off at firewall.
Windshield wipers and motor delete.
Battery in trunk
Headlight buckets removed
Fiberglass SS hood
SS rear wing
150 shot nos wet system with direct inject nozzles on each runner and fogger plate behind throttle body.
Ati crank damper
3000 stall converter
Th400 tranny with b&m ratchet
Billet specialty 15x10s with mt drag radials on rear and skinnies on the front
Traction bars
Eibach suspension
E brake delete
Not sure on diff gears.
LastChance719
Cars Wanted
02-16-2015 11:03 AM
draven666
11-26-2014 07:16 PM
draven666
11-26-2014 07:10 PM
USAirman93
11-24-2014 03:37 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: Traded the bass boat for 98 Z Drag car
