SLP rocker arm's
Re: SLP rocker arm's
I've heard there good for 10-15 hp.
If you ever plan on installing a up-graded cam(even a small cam), stick with the stockers and get a LS6 intake instead with your money.
FYI, you're going to need to up-grade the valve springs too.
So, I'd also highly consider a TSP cam kit(pushrods,valve springs) ported oil pump, LS2 timing chain, cam bolt & gasket kit. This will only cost about $100 more than SLP 1.85 rocker kit and a set of PAC1218 valve springs.
Brandon Wittmer
12-07-2014 12:15 PM
