Shift pressure
Re: Shift pressure
You can increase shift firmness by lowering the numbers in the force motor current vs. temp vs. % throttle position, but you probably should only adjust the ones warmer than 20 deg C and keep in mind that you do not need it banging parts when you are just driving around, so less correction when you are not in the throttle as much.
carguyshu
01-22-2017 11:19 AM
stockssn2o
05-25-2015 08:54 AM
