CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   LS1 Based Engine Tech (http://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   rear main seal (http://www.camaroz28.com/forums/ls1-based-engine-tech-19/rear-main-seal-879118/)
2000z28err 04-30-2014 01:38 PM
rear main seal
ok.. ive had a rear main seal leak since last year. and i have a clunking noise when i accelerate or hit the brakes. bad tranny mount? and would a bad tranny mount cause a rear main seal leak? Thx :(
WhiteHawk 05-01-2014 04:50 PM
Re: rear main seal
I doubt the two are related but it does sound like a bad trans mount. Real easy to swap and you can get them almost anywhere. I wouldn't recommend polyurethane unless you want to feel every single bit of driveline vibration.
-Geoff
2000z28err 05-01-2014 07:26 PM
Re: rear main seal
awesome. i definetly will go with the polyurethane mounts. im on the AutoZone website and shows they have that in stock. just wondering if its the full mount? or do i have to take my old one apart for the bolt?
WhiteHawk 05-02-2014 03:12 PM
Re: rear main seal
You get everything you need in the kit. Again, though, I would recommend against polyurethane unless you have a track car or something.
-Geoff
Injuneer 05-03-2014 02:29 PM
Re: rear main seal
Really varies from car to car. The M6 doesn't seem to be as unforgiving with a poly trans mount. I had the ES poly under my original T56 (a little "buzz" from the shifter) and then under the TH400 and now under the TH400 + Gear Vendors O/D, and never found the noise or vibration to be a problem.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
