Pics of SLP SFC´s?
I don't have a shot of mine that I can post right now....
But...
On the bolt-ons..... The rear attachment point id the forward mount for the LCA. The bolt goes through the bracket on the SFC. There is also another bolt that goes up through a hole in the subframe & screws through a backer plate that you slip up through a hole.
The front has two bolts thqt go up into existing holes in the subframe & a backer plate is inserted into the subrame through another hole.
The center traingulated mounts go the the 2 bolts for the tunnel cross plate.
Gordon
www.provenperformanceconcepts.com
But...
Gordon
carguyshu
01-22-2017 11:19 AM
routesixtysixer
06-23-2002 02:29 PM
