Part # for stock DRL bulbs?
What is the part number for the Trans Am stock bright yellow DRL bulbs, my car has the white bulbs in them, and i think the yellow ones look so much better. Thanks.
Mine uses the standard dual diod turn signal bulb in my Camaro. I think your's uses the same, and so dopes my buddies 25th aniv. trans am. Make sure its the pop in type and not the screw in type....also best way to find out is call the parts department of any chevy dealership because they have the software there, ask them to look it up for you real quick.
Later,
Chris
Later,
Chris
10-31-2016 11:09 AM
