P1153 code
P1153 code
My SES light came on over the weekend, so I went to AutoZone to have them check what was going on. Well, I the car pulled a P1153 code, in which the guys at this particular AutoZone didn't know which code went to what on the computer screen. I wrote down the two possibilities hoping someone here could help me out.
Lack of HO2S21 Switch Rich
or
Bank 2 Fuel Control Shifted Lean
Which description is it and should I do anything about it? It has something to do with th O2 sensor I am sure of that but how bad if at all? Thanks in advance!
or
Originally posted by My84Z
o2's man there goes 80 bucks we can try to clean them with some cleaner then try again.
brian
Brian the only wires I tapped into were the purple ones, but that was a long while ago now, so I doubt thats the problem. I could definitely try cleaning them, but I am not very worried about it right now, because the SES light is out and the car is running jsut fine. Thanks for everyones input.
oh yeah! when I was at AutoZone the prices ranged from like $60ish to $79ish. that was aftermarket stuff too. but like i said for now i am gonna forget about it.
The O2 sensor, in normal operation, is supposed to switch been rich and lean conditions many times during a time period. The PCM monitors this switching every 100 seconds. A P1153 is set when the O2 sensor does not switch enough times.
Usually this code is triggered by an exhaust leak or a bad O2 sensor. And the O2 sensor goes bad either from age, fuel contamination, oil/coolant consumption, or some RTV sealant getting on them.
It could just be temporary. Watch for it. The code will clear after 40 ignition cycles if it is only temporary.
