oil pressure gauge tubing
Old 05-11-2011, 04:59 PM
classics69's Avatar
I have a 98 camaro ls1 and i want to mount a auto meter oil pressure gauge in the port above the oil filter, does anyone have any pictures off the best way to route the line, and if the copper line will be okay, because it will be only a inch or two from the cat and exhaust, i don't know how it is with heat? thanks
classics69 is offline
Old 05-16-2011, 09:58 AM
Marc 85Z28's Avatar
Re: oil pressure gauge tubing
Copper line? You're not using a mechanical gauge are you?
You should be using the electrical setup. Remove the plate, drill and tap for the sending unit, then connect the wire. Really simple. It should clear just about any header - it clears my Hookers.
Marc 85Z28 is offline
Old 05-17-2011, 02:22 PM
classics69's Avatar
I have a mechanical one, but i was worried about routing the copper tubing, so i ordered an electric gauge, does it matter how close the electrical sender is to the exhaust, will the heat effect it? thanks
Old 05-17-2011, 03:02 PM
Marc 85Z28's Avatar
The heat should not affect the sending unit. My Hooker headers are very close to the unit, but almost 7 years later it still works.
Old 05-17-2011, 03:06 PM
classics69's Avatar
Okay well mine will be within an inch of the cat, it has factory exhaust on it, have you had any leaks from the sender? Did you drill that port above the oil filter and run a tap in it? I read somewhere to drill a 5/16 hole and then use a 1/8 npt tap, I am not sure if that is right or not.
Old 05-18-2011, 10:25 AM
Marc 85Z28's Avatar
No leaks. That little plate easily unbolts from the oil pan which makes drilling an tapping much easier. I don't remember what size drill bit and tap is required.
Old 05-18-2011, 01:59 PM
classics69's Avatar
Okay thanks, i did get some of that heat wrap for hoses and wires, i will wrap the sending unit up with that and try to route the wire up around the exhaust some where.
HectorM52
07-30-2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
10-22-2015 07:59 AM
transam_388
03-15-2015 11:53 AM
Z28countrymama
01-22-2015 02:50 AM
07-04-2005 05:00 PM
Quick Reply: oil pressure gauge tubing
