Move Coil packs to Fire Wall?
Old 08-13-2002, 08:07 AM
WantanLS1's Avatar
Post Move Coil packs to Fire Wall?
Relocating the coil packs from the valve covers to the firewall seems like a great idea. Has anyone done this? How difficult is this job, and how much disassembly is required? Who makes a nice set of taller LS1 valve covers?
1986 Buick Regal T-Type TE44, .030" TRW's, 43 lb injectors, ATR Downpipe, wastegate, ram air and exhaust, Lubrant chips, custom converter by Alan, Hot-wired 340 fuel pump, Bilstein shocks, GNX wheels, Ultralite gauges, and the whole METCO catalog
New Better Faster Engine Under Construction
1987 Buick Regal Turbo T 'Old Gray' GM Hi-Tech Performance magazine's project car - Ron Joseph bullet, Stage 5 60-1 turbo, DeQuick VR4 intercooler, Level 10 trans and converter, staged double pumper fuel system, 55 lb injectors, Bilstein shocks, Ultralite gauges, and the whole METCO catalog
2002 Camaro SS Sebring Silver hardtop with ebony leather, Hurst shifter, SLP lid, bellows, and ATS adapter, PS filter, CAGS!, BMR chrome-moly STB, METCO LCA's and bolt-in driveshaft loop
WantanLS1 is offline
Old 08-14-2002, 02:33 PM
SSnyper's Avatar
Post
Anyone have any input?
2002 Camaro SS Sebring Silver hardtop with ebony leather, Hurst Shifter, !CAGS, BMR chrome-moly STB, SLP lid, bellows, & ATS adapter, PS filter, METCO LCA's & bolt-in driveshaft loop
1986 Buick Regal T-Type TE44, stock intercooler with the fat neck, .030" JE's, RJC girdle, P & P'd heads with Ferrea valves, head studs, custom camshaft, 55 lb injectors, ATR downpipe, wastegate, ram air & exhaust, converter by Alan, Hot-wired 340 pump, Bilstein shocks, Enkei GNX-style wheels, Ultralite gauges, and the whole METCO catalog
1987 Buick Regal Turbo T 'Old Gray' GM Hi-Tech Magazine's project car Jack Merkel custom bullet, Stage 5 60-1 turbo, DeQuick intercooler, Level 10 trans & 9" converter, staged double-pumper, Bilstein shocks, Ultralite gauges, and the whole METCO catalog
SSnyper is offline
Old 08-14-2002, 03:11 PM
TheDogofWar's Avatar
Post
Sounds like a pretty good idea. I would love to get them off the covers. Of course you would need longer plug wires an some sort of rack or mount for the packs.
TheDogofWar is offline
Old 08-14-2002, 05:29 PM
maddboost's Avatar
Post
Moving the coil packs themselves isnt that hard but the ignition wires would have to custom made to greater lengths. In GMHT they had a T/A with a 427 stroker and C5R valve covers with relocated coil packs. In the article they only referred that the wires were custom made not who did it or how.
98 Red Z28 A4(3.23) bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
maddboost is offline
Old 08-14-2002, 06:30 PM
Freak's Avatar
Post
you wouldnt need "custom" wires, just order a set of universal V8 wires from MSD, Accell, Taylor, Moroso, or any of the manufacturers out there. Then Cut them to whatever length you need.. chances are they will be cheaper than the LS1 wires too...
Freak is offline
daves91z28
3rd Gen / L98 Engine Tech
05-12-2016 06:19 AM
ad356
04-11-2015 11:12 PM
grabbem88
03-18-2015 01:25 PM
Moshbmx1
01-20-2015 03:27 PM
Quick Reply: Move Coil packs to Fire Wall?
