making changes
Old 12-23-2013, 03:40 PM
joettaylorsc's Avatar
making changes
Thinking of snatching my ls1 out and going with a ls 408....how streetable are they?
joettaylorsc is offline
Old 12-23-2013, 04:39 PM
rwb
rwb's Avatar
Re: making changes
Depends on how you build it.
rwb is offline
Old 12-23-2013, 04:41 PM
Mr99SS's Avatar
Re: making changes
why not 413 ? cam an converter will determine streetability along with gears
Mr99SS is offline
Old 12-23-2013, 05:05 PM
Re: making changes
I haven't even looked at the 413 ill check into it...Mr99SS I live in Sc as well and they who was supposed to do my cam and heads swap has disappeared do you know anyone realiable in the area?
Old 12-25-2013, 07:07 AM
hmmm
Merry Christmas everyone. .....any feedback lsx376 or ls408?
Old 12-26-2013, 11:44 AM
Re: hmmm
While we appreciate the Christmas wishes, no need to start a new thread that appears to be asking if anyone has anything to add to your previous thread. I'll merge this thread with your previous thread, which did get a couple of responses.
Injuneer is offline
Old 12-26-2013, 11:53 AM
Re: making changes
First, let's understand what you are trying to do. You indicate you want to remove your current 346ci LS1 engine, and replace it with a larger engine. Do you want to stroke your current engine to increase displacement, or do you want to consider another block in the LS-family of engines? There are cast iron truck engines that are routinely used, and the various LS2, LS3, LS6, etc. engines that can be used as a base for the build. There is even an LSx aftermarket block that allows huge displacment.
What is your goal - more HP? Just going with a larger displacement does not necessarily increase power a lot. How much the displacement increases HP and where peak torque occurs, will depend largely on the heads and cam selection. The cam selection and the quality of the "tune" will determine "how streetable" the engine will be. A larger displacement engine will generally be more streetable with a larger cam than the smaller displacement.
What are your goals? Without that info, it's really not possible to answer your question in any more detail than has already been offered above.
Injuneer is offline
Old 12-28-2013, 09:13 AM
Re: making changes
Ok my goals is to have a set up that will get a couple of people off my back especially a guy with a dodge charger that has a hell of a set up his self cammed up heads and pro charger sounds like a beast. I want to go with an iron block because ive read that you would have to sleeve an ls1 block to get where im trying be with displacement. Also ive read it wont stand the heat from the nitrous as well...im looking to make atleast 500hp..at the moment I have a 228/228 cam from tsp,5.3 stage 2 ported heads,102 fast intake,3500 stall tsp headers and true duels all sitting in my garage waiting to be installed in my ls1 but I don't think that's going to cut it and I know it wont get me anywhere close to 500 rwhp
Victor Lamb
08-26-2017 02:52 PM
10-31-2016 11:09 AM
RickRay
Events and Cruise Spots
04-23-2015 02:50 PM
InfernalVortex
01-17-2015 09:35 AM
siguy
11-27-2014 10:07 AM
Quick Reply: making changes
