ls6 intake ???
ls6 intake ???
I know the ls6 intake is way better than my stock ls1, but I found an ls6 intake that comes with an ls6 throttle body and fuel rail and injectors, are ls6 throttle bodies and fuel injectors better or even diff from stock ls1, if so would it be better if i could get those items with the intake as well. guys selling it package deal thing
Re: ls6 intake ???
The LS6 throttle body is drive by wire. If you have a Camaro/Firebird, you cannot use it.
The LS6 injectors are the same as the 97-99 and 01-04 LS1 injectors.
It would help if we knew what car you had...
Re: ls6 intake ???
The LS6 heads are where the real magic is- sodium filled valves, yellow springs, better breathing. Add the LS6 cam, and it was good for 405 HP stock from the factory.
I have 2 out of three, and am just a little jealous.
Re: ls6 intake ???
Easiest way to find out if the cam is stock is to remove a valve cover and put a dial indicator on one of the rockers. Measure the valve movement. It won't tell you if you have an LS6 cam for sure, but it will tell you if removing the timing cover is worthwhile.
Re: ls6 intake ???
I don't have time to pull the info right now, but do a search. LS1 and LS6 injectors are not the same size for all of those years. The '99 LS1 had smaller injectors than the LS6 which got a little more RHWP out of the LS1. I've got an LS6 swap in my '98, and can confirm that the '98 LS1 injectors are the same size as the '02-'04 LS6, but I do know the '99's aren't.
hotrodyou1
12-20-2014 10:05 PM
