Ls1 idling at 2,000 rpm after taking out if storage - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 05-14-2013, 08:01 PM   #1
Hey guys!
I have a buddy with a 1998 camaro Ls1 auto, fully stock about 50k miles on it. He went to take it out of storage today and the battery was completely dead. He boosted it with his truck and finally got it going! Unfortantely it was idling at 2,000rpm. He could just tap the gas and it would rev up to 3,000rpm then back down to 2,000? He HAD to move it so he slammed it into gear and it stayed at 2,000rpm. Is this a Safety feature if the battery is completely cooked?? He said the battery is fairly new. Any ideas or where to start? Throttle positioning sensor?
Greg88 is offline   Reply With Quote
Old 05-17-2013, 07:02 AM   #2
transamtom's Avatar
Re: Ls1 idling at 2,000 rpm after taking out if storage
It sounds like the TPS.
Take off the air intake and see if something is obstructing the throttle blade or the linkage.
transamtom is offline   Reply With Quote
Old 05-17-2013, 02:36 PM   #3
rv93's Avatar
i dont think the tps itself could do it. you need the air to spin that fast, especially in gear. I would check for any vacuum leaks, as well as the iacv.
rv93 is offline   Reply With Quote
Old 05-17-2013, 09:26 PM   #4
Yea, he's getting it towed home and that's the first thing I was going to do. Make sure that plunger type thing wasn't stuff in the TB. I guess we'll find out! Thanks guys
Old 08-20-2013, 09:28 AM   #5
The same thing happened to my 98...I didn't drive it for about a month, the battery was fried but when it DID get started it wouldn't stop revving around 2 grand. Replaced the TPS and it ran fine after that. I also replaced the thermostat and flushed the coolant and put new in. It runs like a dream now! The TPS is about $34 so it's a cheap fix and it worked. Run the code to be sure but my money is on the TPS!!
girlgonemafia is offline   Reply With Quote
Old 08-20-2013, 08:06 PM   #6
akwa's Avatar
I would say TPS but before that since it was sitting awhile there is a good chance that all that sludge from the ERG pooled at the bottom of the throttle body and is holding it open. My car has quite a few more miles on it then 50k but I ran into that problem. just pop off that clamp right before it and check it out, takes less then 1 min
akwa is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Project Frankenbird - spring 2015 - D1SC 383 Lt4, advice welcome! LONG dbusch22 Forced Induction 6 10-31-2016 11:09 AM
52mm tb with asr interruption? edman General 1967-2002 F-Body Tech 3 01-25-2015 02:41 PM
Have 52mm tb in 1995 z28, how far do you slot the tps? edman General 1967-2002 F-Body Tech 5 01-22-2015 02:45 PM
Throttle Position Sensor (TPS) A's 91 Z28 Fuel and Ignition 1 01-11-2015 10:58 AM
Words from camaro Brand Manager Rick Baldic Darth Xed Automotive News / Industry / Future Vehicle Discussion 5 07-01-2002 03:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
