Lowering my camaro questions - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 08-09-2013, 01:47 AM   #1
akwa's Avatar
Cool Lowering my camaro questions
I want to drop my ride about 2 inches. Is there anything else I need besides springs and shocks to do this right?
akwa is offline   Reply With Quote
Old 08-09-2013, 03:18 AM   #2
popo8's Avatar
Re: Lowering my camaro questions
I lowered my 96 2"
I did the eibaches all the way around.
I did agx kyb 8 ways I'm the front.
I took the spacer out of the bottom ofn the rear shocks to stand them more upright.
I rolled the rear fender lips because of my 315s
I got Polly bump stops
And
I added drag bags to the rear for a lil leveling when we pack and road trip the car....
Its not all needed....but rubbing and bottoming out sucks.
Just an LTXtech addict
popo8 is offline   Reply With Quote
Old 08-09-2013, 09:16 AM   #3
akwa's Avatar
Poly bump stops is a good idea. were they shorter? and what about panhard bar? do I need an adjustable one? and yeah I want the eibach shocks but do the springs make much difference or can I go with an off brand?
Old 01-26-2014, 12:41 AM   #4
popo8's Avatar
Yes an adjustable panhard is a must as well... Allows u to recenter. If money is not an issue...get one u can adjust while on the car. its a pita to adjust then force the car over to thebside to remount..to repeat and repeat again till i can get it right.
The poly bumps were slightly shorter...but just a better quality for when u di bottom out.
LTXtech.com is my drug.
Old 01-26-2014, 07:51 PM   #5
parkers Z28's Avatar
I lowered my 96 convertible .... NEVER AGAIN ..... nothing but problems ... drags on everything
just my experience
parkers Z28 is offline   Reply With Quote
Old 01-26-2014, 07:52 PM   #6
popo8's Avatar
Old 01-28-2014, 03:27 PM   #7
HANDS DOWN the best way to lower a 4th Gen. F-Body is with Strano Springs and Koni SA shocks! It ain't cheap though...you're looking at $1K in just those 2 sets of parts and you still need the Adj. Panhard Bar as well as LCA relocation kit. However, I learned this the hard way. I went with Eibach springs originally and a set of cheap shocks from AutoZone and the ride was HORRIBLE and it got to the point I didn't even like driving it. I did my research and went with the Strano springs and Koni shocks because I was hooked on the lowered look by that point, but I HAD to get my ride back. The Koni shocks let me dial in my ride. For my daily driving, I've got them on full soft and it really feels like the stock set-up, but if I want to get a firmer ride, that's no problem either to firm up the shocks!
I lost money when I did it the wrong way and then had to take a loss and sell those parts and then buy the Strano/Koni set-up. Do it right the first time and learn from my mistakes.
BandDirector Blk98ZM6 is offline   Reply With Quote
Old 03-22-2014, 03:49 AM   #8
akwa's Avatar
Thanks for the help everyone. I found some eibach springs and shocks on ebay forabout 700 with a 1.5 in drop. ill do the panhard bar as well. for this setup do you think the LCA relocation brackets are necessary? Also I want to run bigger tires (possibly get up to 315's one day) how did you go about the fender? I recently painted my car and don't want to mess that up
Old 04-06-2014, 03:56 AM   #9
popo8's Avatar
Relocating brackets will help keep u from wheel hopping when u spin the tires... inner fender wells... took a bfh... outter lips are rolled using an eastwood fender roller.. but u csn crack.paint.. so be carefull
However see if u need to even worry about that....every car is different.
LTXtech.com is my DRUG!
Old 05-02-2014, 02:24 PM   #10
akwa's Avatar
Is there a difference between the LCA relocation brackets and the adjustable ones as far as quality?
Old 05-03-2014, 03:21 PM   #11
Super Moderator
Not sure I understand your question. Adjustability has nothing to do with "quality".... it's a matter of "function". Possibly you are asking about two different things.
LCA relocation brackets simply bolt/weld to the stock brackets on the rear axle, and allow you to lower the LCA attachment point on the axle, to keep the axle end of the LCA below the chassis end. The only "adjustment" is which hole you put the LCA bolt in:
An adjustable LCA allows you to lengthen and shorten the LCA, to move the rear axle (and hence the tires) forward and backwards in the wheel well. This is primarily of use to position the tires in the wheel wells correctly, and nothing else. It's useful if you are running 28" tires, or running trap speeds in excess of 125MPH where growth of bias ply slicks can be a problem.
Injuneer is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
LT1 Perf Parts: Ported heads, rockers, BBK TB etc... oldschool Parts For Sale 16 02-09-2016 10:21 PM
Camaro Podcast #486 - 2014 Camaro Year End Review ChrisFrez CamaroZ28.Com Podcast 0 12-28-2014 03:25 PM
Tie Rod End Replacement - Some Quick Questions (mostly grease-related) Hurin Suspension, Chassis, and Brakes 4 12-13-2014 08:38 PM
Camaro Podcast #483 - Mustang finally tops Camaro in November ChrisFrez CamaroZ28.Com Podcast 2 12-07-2014 07:01 PM
CyberDeal Weekend is almost over: Storewide and other deals @ PFYC-PartsForYourCar PFYC Supporting Vendor Group Purchases and Sales 0 12-01-2014 09:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
