rear main seal
Old 04-30-2014, 01:38 PM
2000z28err's Avatar
rear main seal
ok.. ive had a rear main seal leak since last year. and i have a clunking noise when i accelerate or hit the brakes. bad tranny mount? and would a bad tranny mount cause a rear main seal leak? Thx
2000z28err is offline
Old 05-01-2014, 04:50 PM
WhiteHawk's Avatar
Re: rear main seal
I doubt the two are related but it does sound like a bad trans mount. Real easy to swap and you can get them almost anywhere. I wouldn't recommend polyurethane unless you want to feel every single bit of driveline vibration.
-Geoff
WhiteHawk is offline
Old 05-01-2014, 07:26 PM
2000z28err's Avatar
Re: rear main seal
awesome. i definetly will go with the polyurethane mounts. im on the AutoZone website and shows they have that in stock. just wondering if its the full mount? or do i have to take my old one apart for the bolt?
Old 05-02-2014, 03:12 PM
WhiteHawk's Avatar
Re: rear main seal
You get everything you need in the kit. Again, though, I would recommend against polyurethane unless you have a track car or something.
-Geoff
Old 05-03-2014, 02:29 PM
Re: rear main seal
Really varies from car to car. The M6 doesn't seem to be as unforgiving with a poly trans mount. I had the ES poly under my original T56 (a little "buzz" from the shifter) and then under the TH400 and now under the TH400 + Gear Vendors O/D, and never found the noise or vibration to be a problem.
Injuneer is offline
HectorM52
07-30-2017 11:46 AM
Magenta_Hearts
03-29-2017 08:54 PM
BigWil
03-29-2015 12:24 PM
carl.froehlich
03-13-2015 12:38 AM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Quick Reply: rear main seal
