CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   LS1 Based Engine Tech (http://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Left hand in a right hand land part 2 (http://www.camaroz28.com/forums/ls1-based-engine-tech-19/left-hand-right-hand-land-part-2-a-876254/)
kiwi rod 10-06-2013 03:23 AM
Chev V8 engines are used in Australian Holdens for years in fact your Pontiac GTO is a rebadged left hand drive Holden Monaro
Years ago I played around with high lift rockers in european engines It meant you could run a consevative cam but have the effect at the valves of a real hairy cam the only problem was unless the pedestals that suported the tappets / rockers were bang on for hight then the tappets / rockers would start clawing the valves side ways & premerturely wear out the valve guides.
Has anyone run high lift Tappets / rockers ?
Any advice ?
Rodney
transamtom 10-06-2013 02:44 PM
Re: Left hand in a right hand land part 2
1.85 would be the max on an LS engine.
WhiteHawk 10-06-2013 06:04 PM
You would get much more bang for the buck by doing a cam than rockers. The stock cams are pretty small, and you can get aftermarket ones that will still drive and idle like stock. Lingenfelter has a GT2-3 that I have run with the stock tune with no issues.
-Geoff
kiwi rod 10-07-2013 11:58 AM
I have been told by one of our better tuners down here that if I replaced the camsharft I should look at 222 - 227 duration
570 - 600 lift
111 - 114 lsa
Does the Lingenfelter match these specs ?
Rodney
WhiteHawk 10-08-2013 08:56 PM
Quote:
570 - 600 lift
111 - 114 lsa
Rodney
No, the LPE is something like 207/220 .571/.578 118. That camshaft you described would be a lot better but you might need to tune it to get the driveability right.
-Geoff
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
