who ports stock ls2 heads the best ?
Old 08-17-2013, 05:16 PM
Mr99SS's Avatar
My tbss has a bad lifter u have to take the heads off to change them. So I wont to send them off to the shop who can get the best #'s out of them . I already have a nos plate kit good for 300 hp ... I got lucky an bought a perimeter plate from harris speed before they went out ... I have a pcm for less cam and the lsxr/t truck intake .... so I need some good heads ....
thanks in advance for recommendations
sprayed it black with high temp ceramic engine paint for the stealth look
best pass tune only with stock 20's is 13.55 with the babby seat an stroller in the back lol
Mr99SS is offline
Old 08-24-2013, 12:51 PM
MachinistOne's Avatar
Re: who ports stock ls2 heads the best ?
Best is a relative term....how much are you willing to spend?
There's quite a few CNC porting programs out there and all of them, including the one we use flow similarly and cost about the same - you're going to pay extra for the use of top quality components and attention to detail when doing the guide work and valve job on the heads. That plus hand porting in the right places after a CNC program has been run can make the difference between regular off the shelf CNC head, and true performance race heads.
There's a huge price spread between the imported cheap valve train parts, and the really good stuff.
What are the specs on the cam? What lobes?
MachinistOne is offline
Old 09-01-2013, 05:29 PM
Mr99SS's Avatar
yeah ive got over 5K in a aftermarket set of v6 heads but also have T&D'S good springs cncd then hand ported an polished .... I think ima just cam an intake the tbss for now. I have the pcm4less rob's cam and to respect them I cant post numbers
Mr99SS is offline
Old 09-01-2013, 06:54 PM
If you want to play the game of asking for help on a message board while withholding pertinent information out of "respect" for a company that's doing nothing special other than drop shipping a cam with their name on it, that's fine...go to them for your advice from now on.
A little hint...when it comes to anything other than custom race cams ground for a specific application and class, you're protecting nothing by posting those specs other than the false marketing scheme that those specs where necessary to keep secret to begin with.
Old 09-02-2013, 07:33 PM
Mr99SS's Avatar
I did before I posted here
how fast is your ls2 ? with what mods ?
thanks for the big help that I was exspecting
Mr99SS is offline
Old 09-04-2013, 01:46 PM
bluz28's Avatar
Take a look a having AI or TEA port you heads.
bluz28 is offline
Old 09-04-2013, 07:39 PM
Mr99SS's Avatar
ty will call them
Mr99SS is offline
Old 09-06-2013, 08:03 PM
97WS6SCharged's Avatar
AI did an awesome job on my 317s. I went with their 232 CNC package with BTR springs and reused the stock valves. Keep in mind you're looking at 6-8 weeks turn around with most CNC shops.
97WS6SCharged is offline
Old 09-07-2013, 06:36 PM
Mr99SS's Avatar
its a small 220/228 cam 114lsa
just bought my electrc spal fans and shroud. Got to order the three relays and then get my comp flashed for electric fans where I can ditch the big clutch fan
Mr99SS is offline
Old 10-14-2013, 04:26 PM
Mike 92LX's Avatar
Ai did a great job on my heads(799s sams as 243s). TEA does good work on them as well
Mike 92LX is offline
Old 10-19-2013, 06:57 PM
Mr99SS's Avatar
thanks trucks been parked for a lil over 3 yrs its sitting on exactly 100k miles ... so the 6-8 weeks will be no problem
Mr99SS is offline
HectorM52
07-30-2017 11:46 AM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
95chwagon
01-13-2015 09:19 PM
Killer94z
01-13-2015 12:06 PM
Brian-94TA
07-31-2002 02:52 PM
Quick Reply: who ports stock ls2 heads the best ?
