how does a bent pushrod cause a loud tapping noise? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 06-29-2003, 03:00 PM   #1
Ive heard people saying that a bent pushrod will cause a loud tapping after doing searches but how does it if it is tightened between the rocker and lifter?
MattysTA is offline   Reply With Quote
Old 06-29-2003, 06:14 PM   #2
I think it is slapping around inside the sleeve...I'll tell you what... my engine started a small ticking noise... and I did have an all famous mis-shift.....and shortly after I started to notice a small ticking noise if you got down near the front passenger wheel-well. So I tore out the valve covers and removed the rockers. From here I pulled the rods, but the were all fine. Pulling the damn valve-covers took an crazy amount of time--they have everything but the spare tire mounted to these SOB's. At this point my hands were so scrathed to hell from the fastners under the dashboard, in the engine compartment, that I was disgusted. I just put the damn thing together. God knows what it is. Sounds more like a steady ticking. Anyone have any ideas?
NJDevils88 is offline   Reply With Quote
Old 06-29-2003, 07:39 PM   #3
steady ticking could be piston slap also. GM service center would know for sure.
crazyswede1027 is offline   Reply With Quote
Old 06-29-2003, 07:45 PM   #4
If you think you have piston slap check out this website, it should help you out LINK
dis3as3d is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Lt1 parts..cam/rockers..etc 13qtr Parts For Sale 24 10-28-2016 09:11 PM
Functional custom hoods for Camaro CARiD Supporting Vendor Group Purchases and Sales 0 09-30-2015 06:44 AM
check fuel pressure with compression tester surreybrad General 1967-2002 F-Body Tech 1 09-29-2015 10:00 PM
4th Gen wiper motor rattles- vibration autoxr166 General 1967-2002 F-Body Tech 0 09-25-2015 05:21 PM
Sputtering under hard acceleration Matt Dreessen Fuel and Ignition 1 09-09-2015 10:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
