High RPM Hesitation - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 08-13-2013, 12:47 AM   #1
High RPM Hesitation
I just replaced my spark plugs and cables on my 2000 Z28 yesterday and gapped them at .060 according to my owners manual. I know GM has changed the gap for spark plugs and all that stuff to .040. My car idles ok though. There has been hesitation since before I changed my plugs and cables and thought it would fix it. After I start to shift into 4-5-6 gear is when the problems occur and the car holds back until I give it full throttle, then it stops. Same thing is happening after I changed everything and the computer is saying it's either a misfire on cylinder #6 or a oxygen sensor which might make sense about the sensor due to the misfire on that cylinder. I am going to change that plug out for a new plug and see if it does the trick. If not what are your guy's suggestions? Any similar experiences?
Jab22 is offline   Reply With Quote
Old 08-13-2013, 08:39 AM   #2
WhiteHawk's Avatar
Re: High RPM Hesitation
Check for a broken plug, and make sure the wires are all seated correctly. I think the wires click twice when you are seating them on the coils.
-Geoff
WhiteHawk is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
1993 Z28 hesitation problem jocamino LT1 Based Engine Tech 13 05-14-2015 07:37 AM
whats normal oil pressure for an LT1?? ad356 LT1 Based Engine Tech 1 04-11-2015 08:49 AM
High Idle 1996LT1Z28 LT1 Based Engine Tech 4 03-08-2015 08:16 PM
Hesitation off idle IRABuss LT1 Based Engine Tech 445 09-07-2011 09:08 PM
Just got back from APE PhantomTA Midwest 12 08-17-2002 12:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
