Guide to Replacing the Oil Pan Gasket on a LS1 - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 09-21-2011, 08:08 PM   #1
Hank'sZ28's Avatar
Hey guys,
For those who have been plagued with a leaky oil pan gasket in your LS1 equipped Camaro like I have, use this guide to walk you through the replacement procedure:
1) Drain the crankcase.
2) Support the engine with suitable support fixture. Thankfully one of my buddies lent me one but for those who do not have access to this piece of equipment, I will try to look up an alternate way of performing the procedure. Any suggestions are welcome!
3) Remove or disconnect the following:
  • Negative battery cable
  • Starter motor
  • Oil filter
  • Left and right engine mount-to-cradle bolts
  • Left and right lower shock bolts
  • Intermediate steering shaft bolt
4) Support the engine cradle.
  • Oil level sensor
  • Left and right closeouts
5) Loosen the six cradle bolts.
6) Lower the cradle and remove the oil pan.
7) Drill out the oil pan gasket rivets and remove the gasket from the oil pan.
8) Discard the old gasket and rivets.
**diagram courtesy of gmpartsgiant.com
--Installation--
1) Apply a 0.2 inch (5mm) bead of sealant RTV sealer 0.8 inch (20mm) long to the engine block. Apply the sealant directly onto the tabs of the front cover gasket that protrudes into the oil pan surface
2) Pre-assemble the oil pan gasket to the pan.
3) Install or connect the following:
  • Gasket onto the pan
  • Oil pan bolts to the pan through the gasket
  • Oil pan, gasket and bolts to the engine block. Snug the oil pan bolts finger-tight. Do not overtighten.
  • 2 lower bellhousing bolts to position the oil pan correctly. Snug the lower bellhousing bolt finger-tight. Do not overtighten.
4) Tighten the bolts as follows:
  • Tighten the oil pan-to-block and oil pan-to-oil pan front cover bolts to 18 ft. lbs. (25 Nm).
  • Tighten the oil pan-to-rear cover bolts to 106 inch lbs. (12 Nm).
  • Tighten the bellhousing bolts to 37 ft. lbs. (50 Nm) for models with a manual transmission or 70 ft. lbs. (95 Nm) for models with an automatic transmission.
5) Install or connect the following:
  • Engine cradle. Torque the upper four bolts to 92 ft. lbs. (125 Nm) and the lower two bolts to 107 ft. lbs. (145 Nm).
  • Side closeouts and bolts. Tighten the bolts to 106 inch lbs. (12 Nm).
  • Starter motor. Torque the bolts to 37 ft. lbs. (50 Nm).
  • Oil level sensor. Torque it to 26 ft. lbs. (35 Nm).
  • Intermediate steering shaft bolt. Torque the bolt to 35 ft. lbs. (47 Nm).
  • Left and right lower shock bolts. Torque the bolts to 48 ft. lbs. (65 Nm).
  • Left and right engine mount-to-cradle bolts. Torque the bolts to 43 ft. lbs. (58 Nm).
  • Oil filter
6) Refill the crankcase.
7) Start the engine and check for leaks.
As I mentioned earlier, if you have any supplemental information that you would like to contribute to this thread then please do!
Hank'sZ28 is offline   Reply With Quote
Old 09-22-2011, 08:14 AM   #2
Moderator
Re: Guide to Replacing the Oil Pan Gasket on a LS1
Did you have a bad gasket from the factory or was the engine apart at some previous time?
I've had the pan off from 3 different LS1s and always reuse the gasket. None of them leak.
AL SS590 M6 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Getting Out of the LT1 Game - LT1 Engine Parts HectorM52 Parts For Sale 25 09-06-2016 07:44 AM
Trans issue PCLZ28 Drivetrain 7 12-24-2015 06:19 PM
LT1 24x Conversion Parts Queens94z28 Parts For Sale 3 12-20-2014 10:11 PM
1996 Trans am part out siguy Parts For Sale 3 11-27-2014 11:07 AM
big block parts for sale Elcojoe Parts For Sale 0 11-17-2014 11:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
