Engine wants to stall
Old 10-03-2013, 04:19 PM
SoLow's Avatar
I have an LS6 with aftermarket cam (unsure what size), LT Headers in an 02 Z28 vert.
I've replaced the IAC, TPS, MAP, MAF, PCV, plugs and wires.
No error codes.
When coming to a stop sign idle drops way down - sometimes around 200 rpm - then back up to ~900, stays steady, and is ready to go.
No vacuum leak that I can detect. Even sprayed break parts cleaner all around the engine and idle never changed.
SoLow is offline
Old 10-03-2013, 05:35 PM
SoLow's Avatar
Re: Engine wants to stall
Here is what my car does @ 3:30 into this video: [autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2808& transactionid=1380839736-768423255&posted_by=SoLow_www.camaroz28.com&youtub e_video_id=jnlFFDmX_iM[/autostream]
First 25 seconds of this video ... that is exactly what my car does as well '99 Camaro Z28 MS3 Cam Idle Electronic Cutout - HD - YouTube
This just the nature of a big cam in these LS1?
SoLow is offline
Old 10-03-2013, 06:33 PM
Mr99SS's Avatar
did u get someone to tune the car for the cam? u need to find out what the cam specs are or put it on a dyno an check the open and closed loop data
Mr99SS is offline
Old 10-04-2013, 08:42 AM
WhiteHawk's Avatar
Hunting idle like you are talking is usually a tune problem. I had my 403 idling at 825 RPM's pretty steadily with a 236/248 cam. It just needs a little more base idle air and it should be fine.
Geoff
WhiteHawk is offline
Old 10-04-2013, 02:36 PM
SoLow's Avatar
The cam was in the car when I bought it. I assume it's been tuned as it has headers and the O2's have been tuned out.
SoLow is offline
Old 10-06-2013, 05:00 PM
WhiteHawk's Avatar
Doesn't mean it was tuned right.
-Geoff
RUENUF
05-25-2016 08:10 PM
ch3vyb1gbl0ck
01-28-2015 04:45 PM
Injuneer
12-15-2014 09:36 AM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
ARFFormula
08-03-2002 09:55 PM
Quick Reply: Engine wants to stall
