energy tran mount
energy tran mount
just picked up my trans mount. ive seen a lot of feed on this saying theres going to be a lot of vibration? lot of people are saying to remove the spacer? on the directions says: upper preload plate must be used. (it is not a spacer).... do I go ahead and install the preload plate they came with the mount? any info on this would be great. thx
Re: energy tran mount
Try it with the plate, and see if it's a problem. I've had the same Energy Suspension poly trans mount, with plate, under three different setups (M6, TH400, TH400+Gear Vendors) in my 94, and no problems. Yes, there is a small amount of added vibration, but nothing objectional. Seems to vary a lot from car to car. The A4 guys seem to have more problems than those with an M6.
You'll never know until you try it.
Front wheels on ramps, or jack the front end and put jackstands under the subframes or A-arms. Block rear wheels. Support bottom of trans w/ a floor jack (piece of 2x4 to spread the load), jack slightly to lift up on the mount, remove mount bolt, lower the trans cross-member, unbolt the mount from the trans.
thx injuneer, tranny mount came off easy. had a little struggle tryin to thread it threw the cross member but finally got it on. what a difference. no cluncking noise. cars nice n smooth didnt feel any vibration, and i did use the plate. the old mount was torn apart ..thx again
BLK1997Z28
05-01-2015 12:23 PM
