Check Engine Light Is On
A few days ago, my "Service Engine Soon" Light came on. I continued driving, went somewhere, shut the car off, then turned it back on, and the light was on. About an hour later, I turned the car off, let it sit for 2 hrs., started it up again, and the light didn't come on.
Today everything was fine, but about 10 min. into my drive it came on again. After letting the car sit for almost 8 hrs., it still came on for my drive home.
Is there something wrong with my engine, or is this just a diagnostic error? I take good care of this car and I hope it's nothing major.
Try resetting your ECM(Computer).
Heres how you do it:
*from InstallUniversity.com *
1. Turn key to the "on" position but don't start car
2. Pull the PCM BAT and PCM IGN fuses in engine compartment
3. Wait approximately 5 minutes
4. Turn ignition off
5. Replace fuses
6. Start the car and then make sure the light has gone off
If this light still continues to come on, get the SES code, that will enable us to analyze your problem. Hope this helps!
5. Replace fuses
Originally posted by SpecForceZ28
5. Replace fuses
5. Replace fuses
What's an SES code?
Thanks for the help so far!
I just got back from AutoZone, where the guy did an SES test for me.
Here's what it said:
P0172
System too rich bank 1
P0175
System too rich bank 2
The guy said it could be a bad air and fuel mixture, but didn't really elaborate any further. I use premium gasoline, have Fram air and oil filters, and have 5.5 quarts of Quaker State 5W-30 in the engine.
I don't know what it could be.
P0172
P0175
P0172
P0175
P0172
P0175
get an ls6 maf...that will lean it out
your in luck...i think i might be selling mine...
email me if interested
stik6shift98@team.camaroz28.com
or aim or pm
thanks
or aim or pm
thanks
Originally posted by DarkblueTA
Sounds like to me you need a few mods on your car I would reset the PCM. That might help out. Otherwise, you could get a 4/5 # Blower and just run on your car and have a little fun. That would help lean it out
What's the PCM and how do you reset it? After the guy removed the diagnostic thing from my car he told me the SES light would stay off for a while, and it hasn't come on all day today.
or aim or pm
thanks
or aim or pm
thanks
I've been holding off on mods because I'm getting 23 MPG. Would mods improve or lessen my gas mileage?
I'll think about that manifold. The problem is, is I'm in Orlando, but, I've got a friend in Clearwater (I saw your post in the FL forum), so maybe if I'm interested I'll have him pick it up from you when you're down there.
Another successful diagnosis, and I like your prescription!
But I don't know how to fix too rich/too lean
Maybe LS1 edit could? But thats $300, a little too much dollars.
Originally posted by TransAmLS1
Somebody on here said some 98s and 99s have faulty cats that go bad. The dealer would have to replace them for free because I believe they have an 80k mile or so guarentee.
