Can someone tell me the paint code for the Black 1998 to 2002 camaro
hi can someone tell me the paint code for the Black camaro from 1998 to 2002 because iam getting my ss hood painted and iam getting the scoop painted black and i need the paint code for the black camaro..thanks
BE VERY CAREFUL...
Believe it or not, there is often more than one paint code for black. One time I had some minor body work done on my black '96. A few days after it was done I noticed that the black paint did not match up quite right. The new paint had like a very faint copper overlay when the sun would hit it just right. It was almost like the glare had a color to it when the sun hit it.
I called up the body shop and they thought I was nuts and sid there is no black blacker than black. I told them I will bring my car in and they will see for themselves. I took it there the next morning and sure enough, in the bright morning sun, you could tell there was actually a difference between the factory black the car was painted with and the new black that was painted when I had the body work done.
Turns out, there were two black paint codes in '96 and they used the wrong one. They had to redo the work they did as a result.
I dunno if this would be the case for a '98-'02 color code, but just make sure you get the right code if there is more than one!
hotrodyou1
12-20-2014 10:05 PM
12-01-2014 08:08 AM
07-04-2005 05:00 PM
