Buying 98 Z28 Auto. What is required to convert to 6spd?
After a long hiatus from the board, I will be buying my brother's 98 Z28. It is, unfortunately an automatic, but only has 80k miles, so I can't pass it up. I don't think I'll be able to put up with the 4L60E for long, and will be looking to swap it out for a t56.
Other than the actual transmission/bellhousing, Master and Slave Cylinder, what all would be required to complete/install the swap? Is there a good writeup somewhere?
FWIW, during my hiatus I had a mudstain/rustang/mustang/insert insult word, and it was the worst mistake I ever made. Glad to be back :P
Location: 5 minutes from the warzone in mexico(south texas)
Re: Buying 98 Z28 Auto. What is required to convert to 6spd?
Here you go
HOW TO: 4L60E swap to T56 (LS1 F-body)
Here you go
Just put a quality high stall torque converter in it. After that, the only time you'll think about a 6 speed car is when you see one in the rearview mirror
the conversion isnt worth it. waiting for a nice 6spd to turn up is nothing quite like one. after you get rid of the crappy stock shift stick anyway. UMI makes a great one for like $25
Here you go
Wow I guess I'm spoiled by having a Bama Tuner for the Mustang, with free tunes for life at $379. It's not quite as full featured, but it works. $500 is kind of ridiculous for hptuners and EFIlive is even more insane, at $900. At that point i might as well do the swap. All I would really want to try is changing shift points, and downshift rpm as suggested. If I was going to do advanced tuning, it would probably be worth it.
That Ford Bama setup doesn't have 1/4 of the capability of what HPTuners offers. For $500, it's worth every penny.
If all you want is to adjust the shift points, don't bother with full custom tune or a HPTuners setup. Just find a mail-order company (I can recommend one, not sure if allowed here) and tell them all you need is a trans tune, and what you're looking for. Most are well under $200.
Not quite as full featured? That's the understatement of the century!
The mail order option could work, and feel free to PM me the info if you'd like. The only problem I see, though, is that I don't think I'd be able to decide what I want my shift points to be, out of the blue. I'd kind of like the ability to fine tune them. Requesting a mail order tune each time would be inconvenient, and costly if I have to mail the PCM each time. Although I'm not a fan of prefab handheld (hypertech, predator) style tuners, the max energy allows shift point adjustment, but not downshift %, and claims 25 ft. lb @ 1500rpm, 12 @ 1000, and 2000. 10 @ 4750rpm, and smaller gains across the rest of the range. Decent HP Improvement at higher rpm too.
http://hypertech.com/PerformanceGrap...bird_32500.pdf
