Bolt-on help
Bolt-on help
to start off i have an 02 ss bone stock. i got some money to put in the engine and i'm gonna start off with some bolt ons..i was thinkin a set of hooker headers, prob 2 rear nitto nt5s cause she needs em.. now i'm not sure if i should stick with that and add to that list or what should i start off with?
also do you recommend lowering it while your addin all the bolt ons?
Re: Bolt-on help
The headers sound like a good place to start.
I wouldn't lower the car as it's already pretty low...
You'll get more out of the headers if you do a full exhaust (high flow cats, cat back).
I'd get a K&N air filter if I were you.
Good luck!
Good luck!
Re: Bolt-on help
the suggestion is to get a cai, but on a 98+ car; really that means - get an aftermarket lid. The ss and ws6 hoods aren't sealed, and while they may give some effect of cooler air at speed; an aftermarket lid still has the same effect as on a regular ls1 car.
well worth it as an upgrade.
Richardan15
05-30-2015 08:36 AM
CARiD
01-27-2015 06:27 AM
SAR2K
12-18-2002 02:26 PM
