SLP Air Lid questions on fit
I put an slp air lid on my car and it doesn't have a tight fit in the back and has minor gaps in the front two corners. is this normal and or will this affect my performance? Is there a way to check this out?
Re: SLP Air Lid questions on fit
Mine also had a gap in the back. I fixed it by adding the foam strip that comes with the lid and also installed the full perimeter foam seal that came with my K&N filter. It's actually doubled up in the rear of the lid, but it sealed up the gap. If you take a flashlight and lean over the radiator you can see if the foam is touching the edge of the filter.
Try a different brand air filter I know a lot of people have had fitment issues with the drop-in k&n air filter over the years, but I don't know if that's still the case (I quit using oiled air filters a long time ago).
95chwagon
01-13-2015 09:19 PM
Geeterman
08-04-2002 04:03 AM
2000silverz28
07-20-2002 06:14 AM
