Engine noise that goes away
Old 09-09-2013, 10:34 AM
Marty0503's Avatar
I have a '01 Z28 with 5.7L Ls1 132,000 miles. I've only had this car about 3 weeks but only mods that im aware of are headers, slp ram air intake and the stock thermostat was replaced with a 160 degree one. Check engine light comes on and only code indicates secondary air injection sytem malfunction. Apparently the air pump has been completely disconnected and removed which is what is causing the light to come on. I've been told I can have the chip re-tuned so that this doesn't happen which I may do sometime but for now that isnt my biggest issue. When I first start the car there is a pecking noise that is very noticeable but goes away after awhile. After a google search and reading about some other ppls experience my best guess is piston slap. The only symptoms I notice that are different in my situation vs others with piston slap is that they seem to indicate that the noise goes away rather quickly, like after a min or 2 of warming up whereas mine takes a bit longer. After first start up of the day I can drive about 1.5 miles down the road to the gas station and still hear the pecking if I roll down the windows or open the door, but then if I drive another cpl miles and stop the sound is completely gone. Any ideas of what this might be? If it is piston slap what if anything can be done about it? I just joined this forum and this is my first post, any input or suggestions will be greatly appreciated, thanks!
Marty0503 is offline
Old 09-09-2013, 01:27 PM
WhiteHawk's Avatar
Re: Engine noise that goes away
Better hope it is piston slap, because the alternative is either valvetrain or rod knock.
-Geoff
WhiteHawk is offline
Old 09-09-2013, 01:33 PM
Marty0503's Avatar
If it were a rod knocking wouldnt I be able to hear it all the time rather than only the first few mins after starting?
Fatdog2
02-12-2015 12:24 PM
jcamaro95lt1
01-24-2015 08:21 AM
ro2207
12-04-2014 06:18 PM
squarehead
11-21-2014 08:02 PM
Omega9
08-02-2002 12:33 AM
Quick Reply: Engine noise that goes away
