Leaking?
Old 05-31-2016, 07:10 PM
mikeZ2878's Avatar
Leaking?
what is leaking? looks like the same color as antifreeze
mikeZ2878 is offline
Old 06-10-2016, 04:13 PM
94Z28LS1toLT1's Avatar
Re: Leaking?
Yes exactly same color,but looks like Freon it's around the ac compressor area. Probably have a Freon leak
94Z28LS1toLT1 is offline
Old 06-10-2016, 06:58 PM
mikeZ2878's Avatar
Re: Leaking?
I noticed as of late the AC does not work....It blows out warm air
Old 06-10-2016, 10:25 PM
Re: Leaking?
Exactly I used to own a different 94 lt1 camaro n my ac was cold before but later on it got warmer n i found the same exact green stuff around the ac compressor
Old 06-11-2016, 10:33 AM
mikeZ2878's Avatar
Re: Leaking?
In other words I have a A/C refrigerant leak
Old 06-12-2016, 12:40 PM
Re: Leaking?
Yea has ur ac blown cold before
Old 06-12-2016, 09:14 PM
mikeZ2878's Avatar
Re: Leaking?
Yes, it was blowing cold air
Old 06-13-2016, 12:40 PM
Re: Leaking?
Yeah then it's for sure a Freon leak then,my lt1 did that before
Old 06-13-2016, 04:32 PM
Re: Leaking?
Dye is usually in the refrigerant to help identify leaks.
shoebox is offline
Old 06-15-2016, 02:13 PM
mikeZ2878's Avatar
Re: Leaking?
Thanks for the help!
Old 06-15-2016, 05:44 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Leaking?
I thought the dye used in refrigerant was only visible by using a UV lamp. Is the leaking stuff liquid now? If so, it isn't refrigerant since that becomes vapor at normal atmospheric pressure.
GaryDoug is offline
Old 06-15-2016, 08:16 PM
Re: Leaking?
Generally I think that is true about the dye, but it seems to be colored in normal light, too.
shoebox is offline
94Z28LS1toLT1
05-12-2016 09:28 PM
z28 justin
05-07-2016 03:26 PM
cmaddox03
03-29-2016 12:19 PM
25diesel
3rd Gen / L98 Engine Tech
03-12-2016 12:24 AM
guitargod33
13
07-03-2002 02:21 PM
Quick Reply: Leaking?
