Buying car w/ 517hp LS2/L92 :D
Old 09-22-2011, 05:47 PM
Dan Baldwin's Avatar
Haven't been on the 'maro boards in a while, but I'm back!
With a question about whether the dyno results for the '94 RX-7 I'm buying (picking it up next week) seem a bit HIGH or if they're realistic:
Actually, now that I look at it I see that the plots are labeled as *engine* power and torque, that might explain it if they adjusted the rear wheel numbers...
The engine is an LS2 out of a Trailblazer SS, with L92 heads lightly shaved to achieve ~11.3:1 CR. LS3 intake. Cam is a street-oriented spec by Patrick G.
Anyway, thoughts and impressions on this build are welcomed!
I've been daily-driving a 2.0 liter S2000 for the past 4 1/2 years, it's gonna be good to get back into the V8 world
Dan Baldwin is offline
Old 09-22-2011, 08:37 PM
raulz28's Avatar
Location: 5 minutes from the warzone in mexico(south texas)
Re: Buying car w/ 517hp LS2/L92 :D
Those look like pretty good numbers especially that nice flat torque curve. What are the specs on the cam?
raulz28 is offline
Old 09-22-2011, 11:03 PM
Super Moderator
JakeRobb's Avatar
When it's a motor swap, you have to consider the possibility that the numbers came from an engine dyno, running no accessories and open headers. I've seen a stock LS1 with just headers pull well over 400hp in that configuration, so a heads/cam LS2 breaking 500 doesn't surprise me at all.
A '94 RX7 with an LS swap...
Post videos once you get it!
JakeRobb is offline
Old 09-23-2011, 06:31 AM
Something like .597" lift, 222 duration, to the best of the current owner's memory. I guess the duration must be at .050"? (I'm used to Datsun L6 cam specs, mine has a 310deg/.550" cam). Anyway, he specifically wanted a very streetable setup that still made good power up top, which is exactly what I want as well. Looks good to me...
Old 09-23-2011, 07:28 AM
It was done on a Mustang rw dyno:
Just seem like BIG numbers to be at the wheels. Similar intake/exhaust/cam mods to a 1.0 liter larger-displacement LS7. Found this on CorvetteForum.com:
Size:  99.0 KB"First is stock, second with bolt-ons: K&N, tune, 160 stat, Vette-Air charger, ported TB & ported intake, and American Racing headers, third is bolt-ons and QM-600 cam"
Logically, mine should look like something between the red and green curves, but scaled down by 6.0/7.0, which'd give ~405 "torques" (damn you, Jeremy Clarkson!) and ~445 horsepower(s).
Owner (good friend, straight-shooting dude, very reliable source) indicates that the 474 lb-ft/517hp are indeed rear wheel numbers, though.
Dyno results thread here: http://www.norotors.com/index.php?topic=4134.0
Will do.
Old 09-23-2011, 05:34 PM
Sparkz28ss's Avatar
FD+LS=boner ........ That is a Badass little car!
Sparkz28ss is offline
Old 09-26-2011, 06:01 PM
Super Moderator
JakeRobb's Avatar
Those numbers on a Mustang dyno are even more suspicious -- those usually rate substantially lower (10-20%) than Dynojets, which are responsible for most of the numbers we're familiar with around here.
Reading through that thread, I found that it's running 11.4:1 compression. I think that's your answer; a stock LS7 runs 11.0:1. LS2 is 10.9, LS3 is 10.7, LS6 is 10.5, and LS1 is 10.25:1. That's a pretty big bump in compression, and paired with the right cam and a great tune, I'll bet that's where the power is coming from.
JakeRobb is offline
Old 09-26-2011, 10:39 PM
Str8boostin's Avatar
Wow, and this is what I told my wife!
I'm picking up a '93 FD RX-7 tomorrow and even though it's on the same stock motor (rebuilt 30k miles ago) I'm going to set funds aside for an LS1 for a swap.
Str8boostin is offline
Old 04-12-2013, 09:01 PM
Doing a random search, came across my old thread here. Might as well update it
LastChance719
Cars Wanted
02-16-2015 11:03 AM
11racing
Classic Engine Tech
12-26-2014 05:40 PM
Queens94z28
12-20-2014 09:11 PM
USAirman93
11-24-2014 03:37 PM
Quick Reply: Buying car w/ 517hp LS2/L92 :D
