94 Camaro z28 Third Brake Light Wont Shut Off
Hey everyone I have a 94 z28 Camaro and the brake lights along with the third brake light will not shut off, and is draining the battery. It stays on all the time and only turns off when I take out the negative terminal. Any help possible will be appreciated Please and Thank you!
Re: 94 Camaro z28 Third Brake Light Wont Shut Off
more likely than not, your brake pedal switch is stuck closed. it should be right above your brake pedal. disconnect that, and i believe the lights should go out. if they dont, youve got a problem elsewhere.
fpete1992
12-11-2014 03:51 PM
sleeperZ96BT
06-05-2005 09:33 PM
