CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   LS1 Based Engine Tech (http://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   4L60E Transmission Issues (http://www.camaroz28.com/forums/ls1-based-engine-tech-19/4l60e-transmission-issues-872253/)
Z28silverstreak 03-05-2013 03:46 PM
Alright here's what I've got. I've got a '98 Z28 that's got 112k miles on her,a mild cam, and a few other bolt on's that are irrelevant. I just picked her up for practically nothing. I've got it running great now, and took it for a quick cruise to see what it would do. It makes the transitions from N-R and N-1 just fine, makes 1-2 fine, and at about 25 mph in second it feels like it goes into neutral. However, from a dead stop it made it to 80 mph in third with no problems. When in 2nd, after it feels like it goes to neutral I let off completely and I can feel it lock back into second. According to my Snap-On Solus scan tool, the TPS is working alright, and there are no codes from engine or trans. Does anybody have any insight on this? Your help is greatly appreciated.
WhiteHawk 03-06-2013 03:35 PM
Re: 4L60E Transmission Issues
Quote:
From a dead stop you were at wide open throttle up to 80? Did you check the fluid?
-Geoff
Z28silverstreak 03-06-2013 03:47 PM
Yes, fluid is right where it should be when hot, is not burnt and is brand new. When I left for the first drive it always seemed like it went into neutral at a certain sweet spot, and if I let off and feel it go into gear, I get all over it and it burns the tires, but under light throttle it does the same thing. Does the TCM need to see throttle percentage separate of the ECM?
Z28silverstreak 03-06-2013 03:54 PM
Also the fluid that I drained was not burnt, and did not have any metallic powder in it.
Z28silverstreak 03-07-2013 03:13 PM
Thanks for the help guys, I ended up removing the valve body and applying air to the clutch apply passageways, and the 1-2 clutch pack leaks a little and the 3-4 clutch pack leaks A LOT...time to yank it out and put a 6 speed in it!
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
